Question about Whirlpool WED5800S Electric Dryer
My dryer WED5820SWD wont stay running unless I hold in the start switch. It happened the other day in the middle of the cycle, also the wrinkle guard stoped working as well. I think that it is the timmer?
  • 39 Answers
Sounds like you have a bad door switch, if it wont stay running and reason for the wrinkle guard not working is the electronic control (circut board) is bad.
Posted on Aug 05, 2010
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
How do I turn off the wrinkel guard?
youcant that i know of unless it gives you that opition on the console just turn off power when cycle is over
May 30, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Auto stop problem.
ck to see if wrinkle guard or some such feature is activated ..most dryers have a cool down followed by intermittant tumble without heat to reduce wrinkles
Nov 17, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool WED5800S Electric Dryer Logo
161 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
