Question about Maytag Atlantis MAV6000 Top Load Washer
Mav6260 washer will not spin
I have a maytag atlantis mav6260aww the machine works fine except for the spin mode, I have checked the bet and it is ok. it spns sometimes, but not fast enough to remove all the water from the clothes. I you open t5he lid when it is spinning the tub stops abruptly and will not start spinning again untill it is filled with water. ANY SUGGESTIONS??????
  • 1 more comment
  • johntheman Apr 28, 2008
    my mav6260 has the same problame it spins but does not spin fast enough to get the water out of the clothes, i have to run it through the spin cycle twice to get the water out of the clothes anyone know whats going on
  • psiceman May 02, 2008
    I had an appliance repair service come to my home and check out my washer. They came to the conclusion that the transmission has gone bad, and needs to be replaced.
  • Anonymous Feb 23, 2009
    maytag washer will not spin but will let the water out
  • 45 Answers
The belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Posted on May 16, 2008
My washing machine maytag wheny out but i had it for a long time no problems untill now with motor burn out is it worth paying $200.00 to get fix or buy new one???
Posted on May 21, 2008
Atlantis MAV6260AWW is not spinning at full speed, its agitating while spinning leaving cloths very wet .
check under lip of washer or around outside of tub. A garment may be in the void between tub and basket. It won't always slow down spin cycle as it may roll around when spin cycle is on but occasionally it will ball up and jam between the basket and tub thus decreasing the spin speed. Socks are a common problem and if you are sometimes whiffing a foul water smell that is the article of wet clothing that has remained wet for some time.
Jan 12, 2015 | Maytag Washing Machines
Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
My Maytag washer has no spinning mode while in rinsing cycle. I checked the voltage-it's about 118 to 130 volt consistantly. Please advise.
Our Maytag Atlantis strted having some unusual operation problems and failure to produce clean clothes about 3 - 4 yeras after purchase. The transmission was replaced, no parts costs, reasonable service call labor costs. Has worked good ever since, another 3 years or so.
Call Maytag and they will discuss with you.
Jun 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
1 Answer maytag washer topload was working fine........but when it came to spin mode it just i rearrange everything and took out all my clothes so now it has only water in it but still...
I would bet your door switch is broken or not making contact try to use somthing to push switch down and see if it works when you do that or it may just be broke off
Feb 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag MAV6000AWQ won't spin
my maytag atlantis does not spin fast enough to get all the water out.
Oct 28, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water fills but does not agitate or spin
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washing machine #mav6260aw
I found the crazy sound where comes from, it was an aluminum ring in the drain pump.
First of all, I took out the belt under the bottom, checked moter to run itself, it was fine, so, I suspected some waste in somewhere, it was lucky I disassembled the drain pump first, no waste in the drain pump, but I saw a ring that was cut under the pump (seems should be connected), when I try to spin the pump wheel by hand it is broken because of the ring.
I ordered the entire drain pump on the website, the cost $74 + delivery fee, I recognized Maytag re-designed the drain pump due to the ring ( new pump does not have the ring anymore). Now the washer works fine like new.
Nov 10, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
316 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
