Question about Panasonic Televison & Video
I pluged the cable line from the cable box into the"ant" section of the tv and it does not work? hooked RCA cables up and it work
    Genius:
  • 1,340 Answers
Either the connector to the cable box or to the TV may not be hooked up properly.I am pretty sure you would have tried those over and over so either there is a problem with the cable box,or the antenna input connection on the TV.At least try disconnecting the cable from the box straight into your TV and check it,you should at least get basic cable stations as long as your cable is activated at least.If you do get basic cable,then the cable box is bad.If you do not get basic cable,either the cable is deactivated or the box is bad.If you are not sure how to get to cable TV options in your TV,you can try autoscan or please let me know and I will reply ASAP.Good luck!
Posted on Aug 05, 2010
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
Tip
How to connect and record on a VCR when you have a Digital Cable Box.
Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
First here are the cables you will need.
3 sections of Coax cable (preferably RG-6 quality)
or
2 sections of Coax cable (preferably RG-6 quality)
1 RCA cable (Yellow/Red/White)
Now here is how you will need to hook up the cables properly.
1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
Now this is how you will need to set your VCR and Cable box to make your recording.
1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
2) Tune your cable box to the channel you wish to record.
*** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
on Jan 09, 2010 | Televison & Video
Hooking my Dishnet work cable to TV modele 27R411T
tuner might be out, try video 1 with the rca cables
http://www.shopjimmy.com/
Sep 03, 2012 | RCA 27R411T 27" TV
No cable however dvds play clear
Hello mrtoyota87,
If cable is on ANT 1,try using ANT 2. If that does not work use video input 1,2,3 on back of TV from the cable box RCA outputs. ( if you have a cable box )
tvdan
Mar 16, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jan 06, 2008 | Curtis-Mathis CM19011 TV
RCA F36676ETFM2
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Open Questions:
Televison & Video Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
