Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I change the light bulb and still no picture or sound. It turn on then off. The red light blink three times. How do I fix the problem
    Top Expert:
  • Sony Master
  • 14,553 Answers
If you have the owner manual it will tell you what the 3 blinks means.
I know it is one of two things: either the lamp door is not properly closed(these sets had a history of the door being warped by heat which causes this----I can tell you a easy way to see if this is your problem.)
The other possible cause (again owner manual would tell you) is these sets also have a history of a thermal fuse failing for no reason.
Let me know if you want to see if it is the door problem----takes ten minutes and you will know instantly.
Regards, SD TECH
Posted on Aug 05, 2010
I just replaced the bulb last week, yet this time the TV will still not turn on and all three lights are still blinking.
It is possible that the replacement lamp is bad but more likely the TV has a protection mode that triggers wen the lamp goes out. Check the manual for ways to reset the lamp usage back to zero or a function that needs to be manually reset when the lamp is changed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
May 02, 2015 | Televison & Video
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times. Please help me troubleshoot this problem so I can order the correct part to fix this...
Please help me troubleshoot this problem so I can order the correct part to fix this television
Nov 16, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Sony grand vega 55" will blink green for three times than red blinking under the power light. nothing comes on no sound, no picture and no fan's are running. Tried to change the bulb, power board...
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
May 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
