Question about Toshiba Satellite A25-S2792 Notebook
I just upgraded the ram in a Toshiba A25-S279 laptop. Following the manual the power button panel was removed, then the keyboard was removed to access the ram. New ram was installed, every thing was put back in place and the power button was pushed. The computer came on but display did not illuminate. Went back in and reinstalled the original ram and turned computer back on and got the same result of the display not coming up. Looked through the manual to determine if a combination of the Fn key + a Function Key might have turned off the display and tried several combinations but did not get the display to come on. Presently the computer is on and the fan comes on every few minutes. This should have been a simple process. Nothing else was accessed in the computer. I am not a novice and have installed ram on multiple computer. Any help would be appreciated. Thanks..............mfb
    President:
  • 2,559 Answers
The power button cover also covers the wires and connections for the display screen, Remove that cover and check for any connections that may be unplugged or loose.
Posted on Aug 05, 2010
I have a toshiba A25-S279 and when i turn it on it shows the toshiba logo and after that it says "password".. iv tryed going to factory settings but it wont do anything ..i tryed "0" i tryed f1 and f8,...
trying to do reset the BIOS,
1. Remove the BIOS battery, leave it for 24 hours. Try installing again.
2. Reset the BIOS with the jumper, http://www.youtube.com/results?search_query=clear+bios+toshiba+A25-S279
Good luck
Jun 01, 2014 | Computers & Internet
I HAVE GONE THROUGH EACH STEP OF THE TROUBLESHOOTER, AND THE SPEAKERS ON MY TOSHIBA SATELITE A25-S279 WILL NOT WORK.
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 30, 2010 | Toshiba Satellite A25-S279 Notebook
What is bios setup key for Toshiba satellite a25-s279
start up computer and it will tell you to press F2 to enter bios do this continually at the post screen or the second you turn it on if you cant see post screen keep tapping it .
hope this helps.
Aug 17, 2010 | Toshiba Satellite A25-S279 Notebook
When the laptop turned on, it's keep beeping all
Sounds like you have a stuck key, When the computer is off brush your arm across the keyboard a few times or try to find the stuck key and use a tooth pick to pop it up. Have you spilled anything on the keyboard?
Jun 05, 2010 | Toshiba Satellite A25-S279 Notebook
Trying to locate the ram
turn laptop upside down and there is a little panal will have 1 or 2 screws in there is the ram
May 06, 2010 | Toshiba Satellite A25-S279 Notebook
How to install 512mb ram for toshiba A25-S279
look on the underside there is a slot for inserting ram in it . but u need to open the back cover to see it and insert in it .
if your product is under warranty i recommend dont do this on your own contact service centre
Apr 05, 2010 | Toshiba Satellite A25-S279 Notebook
How do i change add ram in a toshiba laptop satellite a25-s279 . I don't see on the bottom where to the ram would be?
It's easy to make the old ram-switch-a-roo if there is no trap-door access on the bottom. expose the top of the keyboard by gently removing the trim cover that's in the way (you may see notches on either end to aide in prying up). Remove the 3 screws - there's a bracket on the center one - take note how it goes. Warning - the keyboard is tethered by a ribbon strip/cable - you'll see it underneath the keyboard - leave it attached - it may be a big hassle to put back the right way! Gently lay the keyboard upside down (you may have to remove the protective cover (one screw) over the ribbon). you'll see the memory on the left. lift the plastic shield back and carefully see how to unseat the stick (there is a clamp/arm on each end) then plug-in and then snap-in the new one - it's notched so it can only go in one way. If you do everything GENTLY and can remember the steps you took so you can put the thing back together, you should be OK. You just saved yourself a nice little pile of cash.
Dec 18, 2009 | Toshiba Satellite A25-S2792 Notebook
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
http://209.167.114.38/support/download/files_downloads/SA40/SA40EXUM.PDF
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S2792 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
