Question about Kodak EasyShare M1033 Digital Camera
I have a Kodak M1033 HD. It will turn on but then shuts off immediately. I have replaced the battery and cleaned the lens with no results. Please help!!
Go to : http://www.fixya.com/support/t5301378-kodak_m1033_lenses_stuck_open
i did it at it works now but you have to remove the front metal case(4 screws on teh sides) and blow the air
bonne chance
Posted on Aug 07, 2010
My Kodak Easyshare M1033 camera fell while the lens was extended and now the lens won't go back in plus the camera won't come on. Is it possible the lens is already bad?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 03, 2011 | Kodak EasyShare M1033 Digital Camera
Camera will not stay on
when the len's comes out, try cleaning the glass part of the shutter with your shirt or a clean cloth. This worked for me.
Jul 03, 2010 | Kodak EasyShare M1033 Digital Camera
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
It won't stay powered up
Hi!
Either the lens stucks in outter position or the focus is stuck. It's hard to tell without seeing it and taking apart the camera and lens. You should give it to a local repair shop or Kodak service center.
I work in Kodak service center.
Tom
Sep 26, 2009 | Kodak EasyShare M1033 - black Digital...
Its turns on beeps then shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare M1033 - black Digital...
Kodak M1033 shuts off
Aug 03, 2009 | Kodak EasyShare M1033 Digital Camera
I have a Kodak M1033 camera that I bought just over 6 months ago. I took it on holiday it worked fine and then suddenly it switched off. Since then it only powers up for about 5 seconds, shows a unfoc
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 02, 2009 | Kodak EasyShare M1033 - black Digital...
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
479 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
