I have a razer gaming headset and the right headphone has come off and i have the grounding bronze wire and a red wire i was able to put these two wires on these tin things on the inside of the headphone and they worked but now they don't since i tried to solder it back on. Did i just ruin this headset?
  • 47 Answers
You may have short circuit the speaker for which the wires came off.
Posted on Aug 05, 2010
Minijack color scheme wiring
copper wires get tied together and go to the ground lug, red and white go to the other two pins. will work either way or swap red and white for proper left and right ears.
Jan 15, 2014 | Altec Lansing Audio Players & Recorders
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
Can I replace plug on my Denon overear headphones
If the cord is broken at the plug, most standard sub-mini,mini phone plugs can be replaced by someone with a little skill at soldering ( a ohm meter also helps). Get a replacement stereo plug like the old one (often at Radio shack or any electronic parts store). Cut off the old plug and carefully strip off the outside insulation back about 1/4". Note there is 3 conductors. The webbing around the 2 wires goes to the outside back end of the plug. This is the ground or common wire for both sides. This wire may have a non conducting coating on it which needs to be stripped off before you solder it to the plug. There is 2 other wires in the cord. one (often red) is the right channel and the other is the left. You can check which channel is the right side with a meter or a AA battery. DON'T try to check with the earphones on your head!! The right 'hot' side will go to the tip of the plug and the left side goes to the ring next to the tip. Don't forget to strip off the insulation of the wires by gently scraping them with a sharp knife or razer blade. Also don't do like I sometimes do and forget to put the collar or back piece on the wire before you solder the wires on the plug. Hope this helps.
Dec 29, 2010 | Denon AH-D1001 Headphones
My Sennheiser HD 205 suddenly had a problem with its jack. You have to move its top, nearest to the cord, to get a sound on the other ear, probably it was pulled and something went loose. I spliced it open...
The two copper wires on your headphones are independent grounds for each channel. Twist them together and attach them to the ground cable ( black) of the new plug. The colored wires of the headphone correspond to the live wires of each channel, and the plug should have the same colors. Wiring together the grounds will not affect in any way the stereo separation, it is just that each ear needs its own ground. Cheaper headsets just transfer the ground from one ear to the other one through the metal headband.
Oct 06, 2010 | Sennheiser HD 205 Professional Headphones
My head set just stopped working no sound, mic dosent work or anything, plugged in a second headset to make sure it wasnt the jack, definately something wrong with the razer. any suggestions? where do i...
Possible that the wires would have wriggled off from the jack side due to some ****. to confirm you will need to check one by one afteropening the sides,the continutiy of the wires to the jack and to the mic.
if ther is no continutiy replace the wires and jack. You can also dissect the jack to get to the problem and patch this up after finding the open wire. Ok
Jul 01, 2010 | Razer Carcharias Gaming Headset
Need repair on connector
The connector is called a 3.5mm stereo plug. You can purchase these plugs from electronic shops or Digi-key. It will require some careful soldering with a small soldering Iron. The outer tip is Right, the sleeve is Left and the large back sleeve is the ground.
Inside the headphone cable there are four wires. Two will be likely bronze in colour. These connect to the Ground. One wire is gren. This will connect to the middle sleeve. The last red wire will connect to the tip.
These are 'Litz' wire and contain a cotton fill for support. it can be a bit tough to solder.
Apr 19, 2010 | Bose in-ear headphones - Black with...
Static in headphones
I get the same issue. I think its the headsets itself. I have no problem with any other headset but this one is just static.
Feb 18, 2008 | Razer BARRACUDA HP-1 8 CHANNEL GAMING...
Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
Nov 08, 2007 | AKG K 240 Studio Professional Headphones
Computers & Internet Logo
Alun Cox
David Payne
David Payne
