Question about Kenmore HE2 Plus Front Load Washer
I have a Kenmore f/l washer, model no. 417.431.42200, that will fill but doesn't spin; it just hums. It will drain if I move the knob to final spin, but no movement. The belt is still intact. Tried new motor and different control board but control board was used. Started this two months ago and no one has a solution.
  • Kenmore Master
  • 12,061 Answers
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4?OpenDocument
Service manual above.
Below is a self help DIY troubleshooting and help site between these all you should be able to isolate and repair your unit. http://www.washerhelp.co.uk/diy-repair-help.html
Posted on Aug 05, 2010
  • 1 more comment
  • lansult Aug 05, 2010
    I have a Kenmore f/l washer, model no. 417.431.42200, this is a front load washing machine not a dishwasher??
    Loading... Home FixYa
    My Profile Answer Questions Sign Out
    solutions for every thingShare:FacebookTwitterEmail
    Find Brands Select a Brand to find your product
    Top Brands Top BrandsA A B B C C D D E E F F G G H H I I J J K K L L M M N N O O P P Q Q R R S S T T U U V V W W X X Y Y Z Z 0-9 0-9 See All Brands Categories Select a Category to find your product
    Electronics
    Cellular PhonesVideo Game Consoles
    Digital CamerasFlat Panel Televisions
    MP3
    This was a previous post. No one seems to be able to come up with a resonable solution.
    Electronics
    MP3
    Sorry about earlier posts. No sure how all that junk got in there.
    Not able to get a concise answer on this issue. Can I escalate this as it been over 5 months.
    Message:
    I thought you would find this Washing Machines page helpful -- www.fixya.com/support/t4694235-kenmore_f_l_washer_model_no!
    Send I have a Kenmore f/l washer, model no.Problem with the Kenmore Washing MachinesAds by GoogleWasher Repairs
    www.SearsHomeServices.comGet the Sears® Professionals to Repair Your Washer Today!
    By lansult on May 05, 2010
    I have a Kenmore f/l washer, model no. 417.431.42200, that will fill but doesn't spin; it just hums. It will drain if I move the knob to final spin, but no movement. The belt is still intact .
    I replaced the controller board and motor same result ready to throw the bleeping thing out the window.
    Oh yea, cleaned out the pump as someone suggested that didn't do it either.
    WTF.
    lansult 3 months ago With belt off the drum and motor spin freely. As I stated in my email replaced the controller board and motor with same result. Bought new controller board, motor was used but came from reputable source.
    This washer worked great, one night it started banging. I shut it off and inspected inside found both shocks
    broken. Replaced them and now the drum wont spin. Everything else works perfect it fills, drains just wont start wash cycle or spin. Extremely frustrating. It's only six years old. From what I've read the controller board
    is what provides voltage to the motor. Door lock light comes on and door is locked I don't know what else to try except a sledge hammer. Reply
    Posting advertisements, profanity, or personal attacks is prohibited.
    Click here to review our Terms of Use.
    Comment:
    lansult 3 months ago Is there a common issue with this model not spinning or is it always different. Reply
    Comment:
    lansult 3 months ago Found this on your site but no one has responded. This is exactly what I experienced except I haven't tested voltages.
    Kenmore 41743142200 both shocks broke and now... Kenmore 41743142200 both shocks broke and now it won't start a spin cycle. Moto won't spin or even start. How do you determine is the speed control board or the motor is the problem. No voltage on pin 5
4 Suggested Answers
SOURCE: F/L Washing machine doesn't spin
Normal 0 First drop the lower front panel and remove the pump so you can check the hose leading to the drainpump for debris, coins, etc.
Lower front panel has two? screws holding it in place.
Be prepared for water on floor... use shop vac or have several towels ready for water. Recommend putting at least one towel undermachine before removing pump.
Clamps that hold hose to pump can be a challenger to removeand replace. Consider replacing stockclamps with screw clamps.
This is a great fix.... did it last night.. Found coins, screws, etc. in pump. Once I cleaned out the hose area leading to the pump the spin cycleworked fine.
Posted on May 23, 2009
  • 9 Answers
SOURCE: 417 430 42200 Front load Kenmore washing
Sounds like the pump is clogged or not working. Check the pump on the bottom of the machine. You can see the pump by removing the back panel for access. If you have missing socks or other small items check for a blockage in the pump.
If you set the dryer to spin you should hear the pump groaning if it is blocked.
Posted on Jun 06, 2009
Jahn27
  • 1554 Answers
SOURCE: I have Kenmore 417 40052990 front load washer.
The problem is either an intermittent door switch opening due to vibrations while the machine is working or the timer has dead spots causing it to stop at certain points. But this is more likely a timer problem especially when the machine stops at certain points of the cycle.
Try to push the door while the machine is in operation to eliminate the possibility of an intermittent door switch problem. The timer is indeed the problem if the machine still stops. Fiddle with the timer knob to possibly clear any dead spots and if the problem persists, replacing the timer assembly is the only viable solution to address the problem. Below are links to the timer, part number 131854200, for your machine.
Timer Assembly
Timer Assembly
You don't have to accept or reject this post in order to add information or post comments and follow-up questions should you need further help. But accepting a solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 01, 2011
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Kenmore washer 90 series - 1/2 hour ago we replaced the coupler and clutch because it would not spin. Now, it spins great - if you manually set the knob to spin! It will not move through the cylcles...
the first thing to check is if the small appx. 3/8" diameter clearish rubber hose got disattached from the side of the outer tub espically if before replacing cluctch is didnt overflow
Aug 12, 2011 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My kenmore washer will not spin or agitate. It
i dont know what model this is, but hopefully its a belt type.un plugg unit, place on its side and check if belt is broken or slipping. if enclosed transmission type, it is a big repair.
Sep 04, 2009 | Washing Machines
Apr 22, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore HE2 Plus Front Load Washer Logo
168 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
