Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Can the wire trip for ice maker be adjusted. It is filling to overflowing the container
    President:
  • 2,559 Answers
Yes,just bend it down a little bit and very gently and that will do the trick.
Posted on Aug 05, 2010
Not making full tray of ice
Hello Francois,
Refrigerator set up and adjustment SHOULD be in your owners manual... Sears (service) while usually pretty PRICY ($$$$) on the SAME parts you can buy everywhere... maintains excellent records on MOST brands of refrigerators (make & model required).
To define EXACTLY what you have...
MAKE & MODEL data is ESSENTIAL (not doing so = costly).
On most TYPICAL ice maker heads... (depending on your make & model (which is not presently included here)) there are a couple of minor adjustments ... TYPICALLY.
Some have weeny teeny screws (requiring cover removal AND knowledge WHICH WAY DOES WHAT...other ice makers have quite obvious controls.
- one affecting the duration of the water valve (ergo fill).
- another affecting the trip temperature (ergo hardness/doneness).
If your cubes are too small you can increase the flow duration... up to and PAST overflow (make little adjustments, use patience)
If your cubes are hollow or partial... and usually mal formed or stuck together (decrease the trip temperature (you can significantly drop (or terminate) your ice production with aggressive adjustments in this area
(again: make little adjustments, use patience).
If you are in doubt.. it would be MUCH WISER to get the EXACT information... Ice Maker replacement heads can be quite expensive even from the bargain providers...
Good luck.
appliancepartspros, repairclinic, partsselect... searspartsdirect
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
PartSelect Appliance Parts and Repair Help
Water Filters Lawn Garden Appliance Parts
Mar 20, 2016 | Refrigerators
Seems like my icemaker overflows when filling. I have an ice build up around the plastic box. How can I adjust water
There is not an adjustment. The ice maker dump arm has a cam on it that engages the water fill switch. switch is bad or ice maker motor has a bad spot in it .
Jun 19, 2014 | U-Line Icemaker
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
Large mass of ice cubes frozen together in tray, most likely from leaky ice maker. Can this be fixed without purchasing a new ice maker.
have you checked it when it's filling to see if it's overflowing or the heater on the ice maker might not be shutting off and melting some of the cubes but you have to check,also it could be the water valve,see if there's an adjustment on the ice maker,look in your book,some of them have an adjustment,try to adjust it so less water is coming into the ice maker but to answer your question you might need a new ice maker or a water valve,the only way to tell is to watch it when it fills to see what's happening,you can pop off the cover to the ice maker and jump it out with a piece of wire,in the bottom right hand corner you'll see two holes close together,t and h stick the jumper wire in those two holes and the ice maker will start up,watch it until it fills,if it overflows try the screw to let less water into it,if that doesn't work then it's gonna be the water valve letting to much water come into the valve
Feb 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker seems to be overflowing with water
check for a ice blockage inside that fill tube that sits in the ice maker.
Jan 10, 2009 | Refrigerators
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Ice maker # S10626636 water level adjustment
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Mar 27, 2008 | Kenmore 53552 / 53554 / 53559
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
15 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
