Question about GE 7.0 Cu. Ft. Super Capacity Electric Dryer - White
My dryer asks me to clean the lint trap and will not start once cleaned. I have tried to unplug it.
  • 39 Answers
Sounds like you have a bad thermistor.
Posted on Aug 05, 2010
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Whirlpool cabrio 7.0 cu. ft. Capacity electric dryer will start, turn, and heat. It just won't dry the clothes because no exhaust out of line. The lint trap and the hose has been cleaned.
you have to clean out the dryer too,that's a gas dryer it should be taken apart and cleaned out at least once a year so you don't have a fire.you have to unplug the dryer,pull it apart and clean out the cabinet where the motor is and the gas tube,then clean out the blower wheel and the duct that the lint filter slides into,if the vent line is long stick a leaf blower into the line and blow it out.if you live in ma. and need someone to check it out peter de's appliance is a good service to call 781-438-9442
Feb 16, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Our LG DLE0442W electric dryer is now flashing the Check Filter light and will start, but only run for about 5 minutes before shutting off. I have cleaned the lint trap completely and have also tried...
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Feb 21, 2011 | LG DLE0442 Electric Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Smelled like something burning, then quit working
clean lint trap out more often after every load and try to vacumn inside lint trap lint tends to slip down below the trap and yes it will ignite from time to time My gas dryer did it once and yours it smoked and stunk but because I was home it never went furtherif you open bottom front panel if your machine has one you can get a lot of old lint cleaned out there as well...and most dryers post in their manuals the risk of lint fires
Dec 18, 2009 | Dryers
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer won't turn off.
Is it a mechanical timer you turn (the "clickety-clank"-kind) to set the time? Sounds like something in it has been worn out. Shouldn't be too hart to get a replacement for it,t and you should also probably be able to replace it yourself unless you're very "un-handy", or want to play it safe.
Nov 26, 2007 | LG DLE2514 Electric Dryer
GE 7.0 Cu. Ft. Super Capacity Electric Dryer - White Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
