Question about Exercise & Fitness
Good evening, hope all is well with the experts! here is the problem with my golds gym maxx crosswalk 650 treadmill. the walking belt will not move, however the motor still runs. help, i need to get back on track!!!!!!!!!!!
  • 9 Answers
If the motor is still turning and the belt is not moving then you have two things it could be.
1. the walking belt needs to be tightened by adjusting the bolts at the rear of the machine for the rear roller (equal turns for both)
2. the drive belt is no longer tight or has come off and may need readjusted
did you open the front end to look inside yet? i am willing to bet that if you check these both out you should get it solved since the motor still runs
Posted on Aug 05, 2010
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
I have a Golds Gym Crosswalk 570 treadmill and the screen reads P 26 E 6 82. The belt won't operate and the screen freezes. Any ideas?
More than likely coming from either your controller or upper board.
www.atlantafitnessrepair.com
Oct 18, 2015 | Exercise & Fitness
Maintenance
the walking belt needs to be lubed with a good silicone lubricant. this is put under the walking belt
Aug 21, 2014 | Golds Gym MAXX CROSSWALK 650 TREADMILL...
Rear roller makes noise
most likely the bearings are going bad.try loosing the walking belt and rotate the roller by hand. if you feel any grinding or its not smooth it shoud be replaced. normally only the two adjusting bolts hold it in there
Apr 19, 2014 | Golds Gym MAXX Crosswalk 650 Treadmill...
IFit control Panel on Gold's Gym Crosswalk 570
go to the web site they a LOT of tool +software update for you ifit
http://support.ifit.com/home
God bless you
Feb 07, 2013 | Golds Gym CrossWalk 570 Treadmill
Golds gym crosswalk 650 not working
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
See the block diagram that i did design for easy troubleshooting and diagnose.
2_15_2012_4_24_13_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 15, 2012 | Exercise & Fitness
Golds gym crosswalk 650 no control.
Call the manufacturer at 877-776-4777.
Jan 17, 2012 | Exercise & Fitness
I need the manual from golds gym crosswalk 570
go to www.iconservice.com give you model, etc and download for free.
sincerely. Happey new Year.
ernesto cuadra
managua, nicaragua
Dec 25, 2011 | Exercise & Fitness
Gold's Gym Crosswalk 650 Treadmill belt stops if i am on it, but If i get off it runs fine. How do I fix this?
Hello. Either there is too much load for the motor, or the motor is weak, or the controller in failing and unable to adjust for changes in resistance.
By far the most common problem is too much load. Do the checks in your manual to be sure the walk belt is not too tight or dry. Also check that the motor belt is not too tight, you should be able to twist it 90 degrees. If you loosen both belts until they just begin to slip and then retest you might find the everything is okay which indicates the walk belt may need lubing or replacing. If the walk board under belt looks pitted, grooved, or distorted it also would need replacing.
If the unit passes the tests above and a push test then the problem will be in the motor or controller or possibly both. If the motor passes a walk/voltage output test then it might be okay and you might only need a controller. Unfortunately, it is common for a failed motor to damage a controller and vice versa, and that damage might not show up immediately, so you if one has failed you might consider replacing both.
Mar 22, 2010 | Exercise & Fitness
Exercise & Fitness Logo
207 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
