I was just given a used computer with windows XP but my printer will not work with it. I have a canon bj200e. Is there any way I can get it to work? I can't afford a new printer right now.
    Brigadier General:
  • 6,966 Answers
To my knowledge, drivers for a Canon BJ200e are built-in to the Windows XP. Pls go to Start/Printers and Faxes/Add a Printer. On the next window click on Next, tick "Local printer...", Next, tick "use the fopllowing port: LPT1...", Next, select Canon as Manufacturer and select Canon Bubble-Jet BJ-200e and thereafter follow all other on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
  • 655 Answers
Ok
  1. Remove all old printer drivers which have no use now.
  2. Install your printer driver/software
  3. And use it, there might not be occur any problem.
If any problem, just Ask me..
Thanks
Iqbal
Printer cable from printer to computer
You will use a USB printer cable for this
Dec 29, 2009 | Office Equipment & Supplies
I have a Canon BJC-2000 printer which worked with my old computer. I now have windows xp and I would like to know if I can use it now Thanks
Wow... that printer is still working after all these years? Hook it and, turn it on, boot the computer and see if Windows XP will recognize it as a "plug and play device", if NOT, you out of luck. Canon does not have any updated drivers for this unit. Good Luck...
Dec 03, 2009 | Canon BJC 2000 InkJet Printer
Can CanoScan be installed on two computers?
Most scanners including all-in-one printers can be shared acrossed a network. Hook up the scanner to one computer. At that computer, go into the control panel and to scanners (XP that would be printers and other hardware and then scanners). Right click on the CanoScan and click sharing. You can assign a name to the device. Go to other networked computer and add the device. You should be given an option to locate device on a network. Install the same driver and software you want to use with scanner.
Note: I'm not a Mac user, I've given instructions based on Windows XP/Vista. But, process should be similar.
Oct 19, 2009 | Canon CanoScan 4200F Flatbed Scanner
Scanner
Go to this link. Select Windows XP in the Select OS box. You will see Canon's printer driver for the BJC-2100, and under 'Software' you will see ISScan_v350.exe which is actually the driver for the IS-22, compatible with Windows XP.
Install and download both files on your computer. I know that Windows XP has a driver already for the BJC-2100, but it may not work properly with the IS Scan driver.
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Navigator for pixma mp500
his product can be used with Windows Vista.
  • To use it with Windows Vista, install the software for Windows Vista.
  • The Windows XP software for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP software first; then, upgrade the OS to Windows Vista and install Vista software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall Windows XP software before installing Windows Vista software.
You can download from
Driverscollection.com
Mar 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
GETTING THE PRINTER TO WORK WITH WINDOWS XP
there is no driver for the os windows xp
Feb 24, 2008 | Canon BJC 5000 InkJet Printer
My printer does not work with my new computer.
I bought a windows 7 computer, my canon printer will no longer work, and there is no canon driver on the canon sight.What do I do?
Sep 17, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Need printer driver for XP XP2
Ok. This is going to take a little patience and a little work so bear with me. First since there is no Windows XP driver for this device you will first have to install the available Windows 2000 driver. Go to this link to do so. http://software.canon-europe.com/software/0005192.asp?model= Next, you will need to run a Windows XP update patch to make the Windows 2000 driver work with your XP machine. You can get the update patch here.. http://software.canon-europe.com/software/0006655.asp?model= Be sure to read the XP_PatchInstallation.pdf file to make sure that you do everything in the proper order. After you have completed all the required steps, you should be able to use your C80 on your XP machine. Hope this helps. Good luck.
Jun 22, 2007 | Canon MultiPASS C80 All-In-One InkJet...
79 people viewed this question
jasbo
jasbo
