Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I HAVE SONY WEGA 60". lamp light in frot blinks and TV went dark.I presume I need to replace lamp.Can anyone tell me how to do it?
    Top Expert:
  • Sony Master
  • 14,553 Answers
Model number indicated is a 42 inch, not a 60 inch but lamp should be same for both.
The entire bezel (plate of plastic) under the screen has to be removed; you should find on the back on either side a black plastic thumb wheel that can be backed out (it will not come out but just back out until free).
With the 2 completely loose grasp the plate from the bottom right and pull on it from right to left; it is held in with several plastic pegs and will resist being removed; pull from the bottom as it is also secured at the top with large tabs that engage just under the screen.
The idea is to get it free all the way across the bottom and then lift up on the plate and pull it down and away.
Have the set off and unplugged at this point.
The lamp door will be easy to see and is marked. Usually just one screw and with the set off/unplugged the lamp cartridge is secured with 2 Allen bolts (replacement lamps come with a tool).
The lamp assembly has a handle and with the two bolts backed loose you grasp the built in handle and slide the lamp cartridge out and away.
Average life on the lamp is 2,000 hours.
There are two ways to buy the lamp----Google the model number and use the word lamp after it.
Some sites sell a generic "bulb"; you have to dismantle the cartridge and replace the bulb---I do not suggest this as generic lamps do not in most cases have a good record of long life.
Not to mention if you get a cartridge unit you just have to install it and lock the bolts back.
It is very important when you install it you do not touch the face of the lamp with your hand as oil on you hand can damage the lamp.
Also, it is important the two pin plug that connects the lamp inside the set engage perfectly.
These lamps are considered to be "customer replaceable" but you need to do it right.
Please let me know if you have questions as I am here to help you.
Regards, SD TECH
Posted on Aug 05, 2010
  • AXXMMANN Sep 23, 2010
    thanks i started pulling from the bottom but the resistance was such that i felt i would break it if i pulled any harder. SO ARE YOU SAYING THE "LUGS" THAT SECURE IT ARE QUITE STRONG AND I SHOULD LOOSEN FROM RIGHT TO LEFT ?SHOULD I WEAR SURGICALGLOVES WHEN I REPLACE THE BULB UNIT, AND WHERE IS RECOMMENDED TO BUY THE REPLACEMENT BULB ? THANKS
I have a Sony KP 57WV600 this am it was turne on and a green showed up with blurry screen titles and after a few seconds it went black and the power light blinked several times. Is it worth fixing or replace tv altogether please help<!-- from fixya rte -->
Posted on Aug 15, 2010
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lights
Replace Projection Lamp/Bulb A1601-753A (XL-2000U) THIS ONE IS ON THE RIGHT FRONT COVER REMOVE THE COVER BY PULLING OUT THE LIGHT IS RIGHT THERE YOU NEED TO REMOVE 2 SCREWS Replacement Projection Lamp/Bulb A1601-753A (XL-2000U)
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv will come on but shuts itself back off
Sounds like it just needs a new lamp.
The way to tell is the lights in front:
green blinking as TV reboots = bad lamp
red three blinks = door switch
red four blinks = bad fan
6 or 9 blinks = bad thermal fuse
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony Wega KDF-60XS966 is dark You can see the picture and the brightness is turned all the way up but it still looks dark Do I need a bulb?
Yes, its time to replace lamp in tv.
Lamp replacement is easy and procedure would be written in user manual.
Thanks.
Jun 10, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Mar 16, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega, 60" LCD
I hope you know the light engine to these sets cost 1,900.00 up to 2,500.00 also did you reset lamp timer when you installed new lamp to tell set lamp has 0 hours on it?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
