Question about Pioneer DEH-2100 CD Player
Hi I'm having a few issues with my deh 2100 head unit in my VY commodore. I installed it myself with the right wiring harness but the head unit doesn't remember settings or band settings. Also when the head unit turns on my aerial doesn't go up. Thanks for your help it's becoming a really annoying problem!
  • damobj7 Aug 05, 2010
    Thanks for the help. The unit just connects using the wiring harness though so shouldnt that have all the connections secured properly?
  • 407 Answers
When a head unit doesn't remember settings like yours, then the Yellow constant battery wire isn't hooked up correctly. This wire provides power to your unit constantly from the battery so that it can remember the settings and such. Your aerial not going up is the Blue power antenna wire. This wire will provide power so that when you turn your unit on, it powers the antenna to go up. Hope this helps!
Posted on Aug 05, 2010
  • damobj7 Aug 07, 2010
    Hey thanks for the help. How can I fix the wires? All my wires go through a wiring adapter which I thought would make sure all the wiring was right. Do you have anymore tips?
  • robbiemac53 Apr 24, 2011
    Hey bud. On the black end of the wiring adaptor (the one that plugs into the car) carefully take out the yellow (constant memory) as well as the Red (acc) and swap them around. I found this out from another person with the same problem (as I was having the problem too) and for some reason Aerpro or whoever makes them did it wrong. Mine works great now and saves all my stations and where my cd is up too
Oil capacity for VY commodre
hey I will give you all the information I know as you haven't given all details.
VY COMMODORE 3.8LITRE V6
Crankcase service refill =5.5Litres
Manual Trans 1.2Litres
Auto 4.8Litres
Diff 1.7Liitres
VY COMMODORE CALIAS 5.7LITRE
Crankcase 5.0 to 6.2 Litres
Manual Trans 4.4 Litres
Auto 5.0Litres
VY ADVENTRA 5.7
Crankcase 8.0Litres
Auto 5.0 Litres
Diff 1.5 Litres
hope this helps if you need more please contact.
Dec 13, 2013 | Cars & Trucks
How to remove a deh 21001b from a vt commodore
He may have to get underneath the dashboard and see if their is a security strap or wire harness holding the radio into the mounting sleeve. It's common for installers to strap down the stereo to prevent thefts and other installer from easily taking the radio out. Have him keep trying.
Nov 26, 2012 | Pioneer DEH-2100 CD Player
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Im trying to fit an aftermarket stereo in my vx ss commodore but cant find a wiring diagram to hook up the controls on the steering wheel
hi i have done some research and all that i could find on your car (i line in the us so i never heard of that car before today) and this link will take u to the car audio forum discussion on the same question that u have asked and one of the people talking in the forum writes that u can simply buy an adapter to get the wheel controlls to work and another adapter for the head unit itself and here it is
http://forums.justcommodores.com.au/car-audio/55456-pioneer-headunit-into-vy-commodore.html
they also talk about a fascia and give the company that makes it name and part numbers
hope that helps ohh and you can find some commodore wiring diagrams if u search with google and just look for images
like i said i hope this helps
sincerely
justin
May 21, 2009 | Car Audio & Video
Automute car kit for Sony Ericsson OEM HCB-300
I am having the exact same problem with my vauxhall corsa and my pioneer deh-6000ub its so annoying it works with the manufacture stereo soon as i connect my pioneer in it doesn't come alive (the HCB-400)
Mar 13, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
How to install pioneer DEH-2850MP stereo player
Shouldn't need to take out *too* much. I've changed the stereo in my last two Commodores.
Usually, you'd unclip the shifter-surround, which then exposes more screws for the DIN units. Undo those, and take out the ash-tray if it's nearby... eventually you'll get to the DIN mounting-bracket and be able to unscrew and unplug the existing headunit. Wiring and crimping the new unit into the existing wiring loom is fiddly, but you can buy adapters from Strathfield Car Radio to convert most popular brands to Commodore's/Falcons/etc.
A full guide with pictures is a bit much for this response, but that's the general jist!
Aug 20, 2008 | Car Audio & Video
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Vt Holden Commodore stereo wiring diagram
Here are the wiring codes for the VT,
VN-VT Commodores:
Accessory (12V) Yellow
Battery (12V) Orange/White
Ground (earth) Black/White
Antenna power (12V) Yellow/Red
Front Left + Tan
Front Left - Grey
Front Right + Light Green
Front Right - Dark Green
Rear Left + Brown/Black
Rear Left - Yellow/Blue
Rear Right + Blue/Orange
Rear Right - Blue/Black
Antenna Up White (VR-VT)
Antenna Down Blue (VR-VT)
Phone Mute Yellow/Black (VT)
Dimmer In (12V) Brown/White
Dimmer Out (12V) Grey (VT)
May 18, 2008 | Car Audio & Video
Pioneer DEH-2100 CD Player Logo
177 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
