Question about Ricoh Aficio SP C811DN Laser Printer
I installed a new Magenta cartridge. The machine says that toner is loading. The loading cycle finishes, but the out of toner message remains.
  • jsgibson50 Aug 05, 2010
    I already have the Ricoh manuals and they do not address the out of toner message issue. The issue is why doesn't the printer recognize that a new toner cartridge has been installed.
    Helpful, but didn't produce the final solution. A Ricoh serviceman came and unclogged the toner tube assembly for the magenta toner.
  • 3,083 Answers
I couldn't find any reset information on this machine, but many of the printers these days "guesstimate" the number of copies a cartridge will provide. Some use a sensor window on the cartridge, that can be covered with tape, but the software estimating has to be reset. A lot of people have complained about this problem, and you can google blogs about it. Here's all I could find for a solution to the problem, and people jiggled the cartridge- perhaps that covers a sensor area:
Our Ricoh printer / cartridges has this issue – I remove the cartridge, shake it a bunch and replace. This will usually get me about 200+ copies before I really have to replace it. It’s worked with black and colors.
Here was one answer to a similar printer by a FixYa expert, perhaps it will help:
http://www.fixya.com/support/t5065240-ricoh_cl7000_keeps_asking_replace_yellow
Here was another suggestion by a FixYa expert:
Best Solution posted 4 months ago
I installed a new Magenta - noavatar.png ronrejjr
  • Rank: Wiz
  • Rating: 83%, 43 Votes
cycle the copier 1 to 5 times.. obviously it was either under toned and needs to cycle or you didnt remove the packing material from the toner befor you installed it ...check that too...
Same problem you're having, just different cartridge.
If nothing helps, consult your manual, or contact Ricoh support:
http://www.ricoh-usa.com/support/
Good luck, and hope this helps.
Posted on Aug 05, 2010
    Genius:
  • 1,040 Answers
Visit to the given link and download the hardware guide and manual. This contains information required by you...
http://www.generalmanual.com/Printers/Ricoh-Aficio-SP-C811DN-Color-Laser-Printer.htm .... http://www.retrevo.com/support/Ricoh-SP-C811DN-Printers-manual/id/23013ci965/t/2/
Thanks...
Sp c821dn printer displays "out of toner" magenta message even when magenta toner is replaced with new one.
is their toner in the new cartridge installed? if not you have to refill the magenta cartridge and do the calibration of the printer
Apr 07, 2017 | Magenta Office Equipment & Supplies
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Magenta toner brother MFC9450C everywhere in printer
Take out the magenta cartridge and clean the nozzels and contact and reinsert it. if the issue persists get a new genuine brother magenta cartridge
Apr 20, 2012 | Brother MFC-9840CDW Laser Printer
Error message 88 Replace magenta
Magenta is one of the colors of toner you need for it to run. You will need to install a new color cartridge.
Mar 01, 2011 | Lexmark C534dn Color Laser Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Replaced Toner and Still Wants it to be replaced
You need to manually reset the CRU counter in the service menu to reset the toner count. This is designed so the xerox tech can come in and get paid for work. What you do is the following:
Enter the service mode by turning the machine off....then hold the (i) button and (<) arrow button simultaniously while turning the machine on. Then go down to nvram access enter menu, then go to CRU menu. Then go to the Toner CRU count menu, then select the toner you wish to reset and allow the machine to reset.
IF you need any parts feel free to come to my store
Andrew www.Getthatpart.com
Apr 23, 2008 | Xerox Phaser 7300DN Laser Printer
Ricoh Aficio SP C811DN Laser Printer Logo
76 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
