Question about Frigidaire GLEFZ379FC Electric Kitchen Range
I have an issue that just started with my Frigidaire GLEFZ379FC. I'm getting the F10 error code. I remove and checked the resistance of the oven probe and all is good. I put the oven back together, powered up and set it to bake @ 350, just so I could watch it. Only the upper element seemed to work and glowed cherry red. I rec'd the same code again after about 7-10 min and the oven temp was 450 degrees (I placed an oven thermometer inside). My question is do I need to and is there a way a way to check the EOC? Something is amiss as it seems that the upper element is doing all the work and is not being controlled by the temp settings Any advice would be appreciated.
jyackle5
  • 8197 Answers
SOURCE: instructions for frigidaire oven
an f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
fixyourboard
  • 310 Answers
SOURCE: F6 ERROR CODE ON MY FRIGIDAIRE STOVE.
dagadier
We may be able to repair your EOC, what are the symptoms?
- www.fixyourboard.com
Posted on Jul 26, 2009
  • 145 Answers
SOURCE: frigidaire Model fgfl79gsa EOC won't lite up
If it has 120 volts to the EOC, with a good line and nuetral, and it won't show the clock or turn the oven on it has to be replaced. Frigidaire doesn't offer repair parts for the EOC.
jim
Posted on Jul 28, 2009
  • 67 Answers
SOURCE: Hi, I just purchased a second hand Frigidaire
the previous owner was on lp gas, you are on natural gas. the orfice ratings are different. call a professional to convert the range back to natural gas.
Posted on Sep 29, 2009
I have a frigid are range and I first got a f 10 alarm that would not reset. It finally stopped after 5 min. When I tried to restart I get and f 30 alarm. How do I reset oven.
Thank you for your post, Doug!
I see that your Frigidaire range is displaying the error codes of "F10" and "F30". An "F10" error stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). An "F30" error code stands for an open probe connection this could be a problem with your RTD, EOC, or sensor probe. I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If this does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 27, 2016 | Frigidaire Kitchen Ranges
My Frigidaire oven shut off due to an f10 error which should I replace first since I have no tools to measure.ohms... sensor or EOC?
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
Feb 14, 2015 | Frigidaire Ovens
What does it mean when F-10 shows on oven display frigidaire range
Good Afternoon friend, thanks for your post!
Based off the information you have provided your range is displaying an "F10" error code. "F10" typically means that your wall oven has detected an issue with the runaway temperature (overheating).
Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. I hope this information is helpful. -Matt
Oct 18, 2014 | Frigidaire Kitchen Ranges
F10 code meaning for Frigidaire range?
Thank you for your inquiry, friend!
Oct 04, 2014 | Frigidaire Kitchen Ranges
Getting f10 on oven
Hi Dave, thank you for allowing me to assist you!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 22, 2014 | Frigidaire 30 in. Electric Gallery Series...
What does a f10 code mean?
Good Morning Friend, that's a great question!
Aug 11, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Jun 03, 2014 | Frigidaire Ovens
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
Frigidaire range F10 error and very hot
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%ER
Jan 02, 2009 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire GLEFZ379FC Electric Kitchen Range Logo
57 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
