Question about Sharp Office Equipment & Supplies
How to enter into service mode on sharp 2014 copier,old machines used to be CROP,CPOP
  • 1,110 Answers
Going way back into my memory bank here. You have listed 2 possibilities. The other 2 from that era are C 0 0 C and C, interupt, 0, interupt
One of these 2 should work.
Posted on Aug 05, 2010
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
H4 error 00
Error code is for heat-roller which has an abnormally low temperature
the fusing unit on that machine could be dirty and the thermistor and thermostat could need cleaning to remove the paper dust ash build-up,
OR
the fusing unit`s halogen bulb needs replacing which is rarely the case
OR
and most likely scenario is that because of a power fluctuation it enters into that error as a sort of safe-mode
the error needs to be reset by a technician such as myself which is familiar with Sharp copier CROP system , a CROP 14 should clear the error
if it was a power fluctuation the error should go away, if not
take it to a technician (qualified preferebly)
Oct 07, 2013 | Sharp AR-M550U Copier
Windows7 driver for my SHARP AR-5316
use a vista driver... or xp... and use compatibility mode on the driver... the driver may not be out yet... if it is it will be on the sharp support website...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp copier al 1600
Means low heat roller temperature - the heat roller is a part of the fuser unit, which fixes the toner to the page so it doesn't rub off. This can usually be solved by switching off at the mains for 30 seconds. If this doesn't work try using a "crop code". Put the machine in copy mode. Press # * C * (or # * Interrupt * on some machines) in quick succession. The display should change or go blank. Type in 14, then press start. If it asks are you sure, choose yes. The machine should then restart. If not, switch off and on again. This should clear the fault. If this still doesn't work you may need to replace the fuser.
Jan 23, 2009 | Sharp AL 1631 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
H-3 error code in a Sharp ARC260m
The analog Sharp copiers used the crop code (clear, repeat, zero, pause).  Once the digital models came out the rules changed.  Sim 14 was for the analog copiers as well.
A good resource to get the answers you need is copytechnet.com.  They have Sharp copier technicians on there who can help you with the problem.  Unfortunately I only work on the low end Sharp models (for their product line).  The service codes are different on that machine. Copytechnet is a free service and they only deal with copiers.
Oct 03, 2008 | Office Equipment & Supplies
Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Jul 02, 2008 | Sharp SF 2020 Copier
Cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Sep 14, 2007 | Office Equipment & Supplies
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
