Question about Kenmore 24 in. 16222 Built-in Dishwasher
Have kenmore quiet partner 1 dishwasher. Fuse failed a year ago after 1 year in service, panel has no lights, suspect fuse again. Need to know fuse location and description of fuse
  • 760 Answers
You didn't list model number. remove screws on inside of door to have access to controls. There should be a thermal fuse square object with two wires attached. Some brands now come with short pigtail wires, so bad terminals are eliminated. IF it's a kenmore, then go to www.searspartsdirect.com You can see parts diagram there.
Posted on Aug 05, 2010
Gold Quiet Partner lll. Why are lights flashing on normal, pots and pans, and cancel?
I had this happen and I was unable to cancel, so I believe I resolved it by flipping the breaker off, then back on, and it's been working fine for a several years since then. Your electric panel should have a separate switch/fuse for the dishwasher. Some have a plug under the sink, but most are "hardwired". Cheers.
Dec 26, 2015 | Whirlpool Dishwashers
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
I have a whirlpool Quiet Partner 1- it is tripping the breaker in my fuse box.
from the way you asked about this,,, you should call for service.
Jan 30, 2012 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwaster quiet partner I - 5 years old
it could be bad thermal fuse or loose wires in jbox at bottom .to chkd therm fuse remove the screws the on top of the door holding the control panel.then pull out the panel and u should see cntrol board on the rhs of the panel.the thermal fuse is mounted on rhs corner of the control board.remove wires from fuse and chk for continuity.if open replace.if ok remove toe panel at the bottom and remove the screw of j box at rhs bottom corner.chk for loose or burnt wires.do not forgot to unplug the unit from power before doing all this.good luck
Aug 18, 2009 | Dishwashers
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool quiet partner dishwasher seems to have no power
Ok there is a thermal fuse mounted on the control board that shuts down when it gets too hot. Did you run a sanitize cycle? Even if customers dont use the sani cycle which i recommend the fuse may open due to poor wire connections. The new fuse kit comes with a new harness and new connectors. Check the old fuse to be sure its bad. Dont remove the connectors from the new switch at all - dont disturb them and they will work better.
Dec 02, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Thermal fuse for Whirlpool Quiet Partner II
while it is possible that something could be drawing too much current, it is not likely to cause the "thermal" fuse to blow. what i would like to know is, did you use the wiring kit made by whirlpool to replace the wiring? if not then you probably arent getting a good enough connection on the thermal fuse itself.
what causes a thermal fuse to fail is ... get this... too much heat. so a loose connection is the most likely cause. check with your parts house and see if they can find the right repair kit that comes with a wiring replacement with the thermal fuse.
Sep 03, 2007 | Kenmore 24 in. 16222 Built-in Dishwasher
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore 24 in. 16222 Built-in Dishwasher Logo
240 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
