Question about NEC Cell Phones
We have a NEC NDK 9000 commander system. The power went off and it a defaulted back to a different setting. Only the two program phones ring in the house (not all 24) and the intercom rings instead of Voice speaker. I have theses instructions which are not working all phones to ring FNC #0 Press 4 (top phone key) 01/01 - day ring press call 01/02 - night ring press call (do for all phones) Voice speaker for Intercome FNC#0 8974-Program Mode Press 1 2 (top keys) see 00 Flash Press 0 1 (bottom keys) Press Call button (02 is for ring tone 01 is for voice line) Can you advise if these are the correct programing keys.
zaids
  • 456 Answers
SOURCE: setting ring tones on samsungsgh-a411
thtats related to sim provider in mms its psible
Posted on Nov 27, 2007
SOURCE: LG Scoop after using BitPim
mine is bad to the screen is done for lack of a better word
Posted on Sep 20, 2008
  • 4 Answers
SOURCE: Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
Posted on Nov 08, 2008
SOURCE: "NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
Posted on Dec 17, 2008
Dipu007
  • 2110 Answers
SOURCE: how the "play caller name " system is work. plz tell me all steps
Goto menu>setting>General>Voice control>play caller name>select on
then back to voice control>voice dialing>activate>edit names>then record sound for desired caller name...
Posted on Jan 15, 2009
Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
Mar 04, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I NEED TO ANSWER THE NEC DTERN 8 WITHOUT HAVING TO HIT THE LINE BUTTON THAT IS RINGING
If your phone is set to ring then the Answer key should also flash during incoming call, you can use that. If its not set to ring there is a program to set Answer key to flash without the ring, but it's in system programming, likely a vendor thing.
Jun 11, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a NEC NDK 9000 PABX fault after relocating phone lines,1 extension is not working and the other 2 are, I have noticed there is a red light flashing on one of the cards and am assuming there is a...
Each PABX or telephone system needs its own driver as each system has its own output format for the SMDR port. Therefore the MonTel system must have a suitable driver (technically a receiver) for each type of PABX that it can support.
http://www.netwiz.com.au/appnotes/1872.htm
May 10, 2008 | Lands Phones
Make the phone ring
you must assign ringing in program mode. MB 4-01 day and 4-02 night. if this is an elite or ipk. If its ipk2 or 2000 than MB's are different. ldtsnj.com
Mar 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Additional User Stations not Ringing
You would need to determine which NEC phone system you have and obtain a programming manual for the phone system. Your phone could be used on different NEC phone systems that program differently. Phones only have user guides that explain how to use the features.
You can set up your system with Night Ring and have different ringing rules when the system is put in night ring mode. It sounds like this is what you are looking for.
Nov 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Ring and paging system
I have seen cases where programming can be messed up or even set back to default with rapid on-off-on-off power surges that often happen in power outages. The system will need to be re-programmed. I have never programmed an NEC system but here is what you need. Either find a local installation company that can fix this for you OR figure out which NEC phone system you have and locate the Programming and Installation manual for it. (not a user guide or administrator's manual) The phone's part number will not help you figure out which NEC system you have, it only narrows it down a bit. Look for the main control unit in the basement, utility closet, etc.. Programming any phone system can be daunting for someone who has not done it before even with the right manuals. If you are not up to it, look for a company that can help. MAKE SURE the system is defaulted before re-programming it! There could be a glitch in the programming that cannot be fixed without a system default so you want to do this before making any changes. Also, I would highly suggest a UPS backup power supply for the phone system. This will keep it running for a short time in a power outage and will stop this from happening again. If you have a small system with 1-12 phones, most small UPS systems made for computers will work. Small phone systems use less power than a computer and monitor.
Aug 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Cell Phones Logo
110 people viewed this question
Top NEC Cell Phones Experts
Computer Repairing
Computer Repairing
Starnley Johnwells
Starnley Johnwells
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
