Question about Sony Playstation 2 Slim Black Console
My playstation 2 powers on for about a minute then shuts itself down and the light on the power button starts blinking. tried multiple discs in the unit and does the same with all of them.
    Scholar:
  • 203 Answers
Sounds like there is an issue with your power supply. Try replacing the plug that goes to your PS2 Slim. If this doesn't work, then it's an internal problem and your best bet is to contact the Playstation company
Posted on Aug 05, 2010
When i turn my playstation on, after 5-10 seconds it shuts off by itself and the red light keeps flashing, what do i do?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
The PS3 red light problem occurs when your system refuses to boot up and has a small flashing red light on the power button. In most cases, the power button will turn from red to yellow and then back to a blinking red and the system will not boot up from there as it is supposed to.
There can be a variety of issues that cause the Playstation 3 red light problem, but in most cases it comes down to the system overheating. The more it overheats the more damage is created internally to the motherboard
and other functioning components. This can be caused simply by a flaw in the system or by obstructions to the fan vent such as a wall, floor, or excessive collection of dust...
click here to download repair guide
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
PS3 shut off with blinking red light, there is power, ejected cd.
The blinking red light means the system has over heated and normally the system will shut off by itself and will not come back untill cool.(but not in all cases does the system work completely correct in that situation).
The hard disk may possibly have something to do with this occurance, but I honestly doubt it.
It may be the system final moments until it dies but it may be fine.(the normal life span of a ps3 is about 2 yrs.)
If it's not just the system crapping out it may juss be the power supply and I would do some trouble shooting in that area but again,I am doubtful.
Smart thinking about taking the game out and I would advise don't put it back in until you know for sure that the system is good (because honestly MW2 is TOO awesome to risk it!!)
If all else fails, you could call SONY but if they can't fix it over the phone then they will want you to trade for a refurbished system for $150 or if its under warranty it's free.
I hope I have helped and I hope it all works out!!!!
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
I press the power button, and it lights up and I
ok so in this situation you need to call sony. its broken, but there have been reports of people "roughing up" their ps3's to get them to work, try unplugging everything, and flipping the power switch to off, on your ps3, then plugging it all back in and turn the witch on, they say after about the 4th to 5th try you can get it to boot up, my suggestion is to never turn it off after that, but dont hold me accountable for whatever happens. this is what ive read on the internet
Jul 20, 2009 | Sony PlayStation® 3 (80GB) Console
PS2 Shuts Itself Down
hmm, annoyingly this is quite a common problem on the early releases of the slimline Ps2 models. The power supply units get to hot and can cause this problem. I'd recommend getting an updated PSU unit which will be available online
Mar 23, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Tv turning itself off
without holding the power button down, What does the power light do when you press power just once? Please respond to this same post so I will have your model number available.
Jun 26, 2008 | RCA D52W19 52" Rear Projection Television
Sony Playstation 2 Slim Black Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
