Question about Husqvarna 160 CC Honda OHC Engine 21 in
My husqvarna lawn mower 7021 ch1 with brigg n straten 7.0 motor It is 2 summers old it was running great I went to mow the next time and it will start but runs for about 3 seconds,We drained fuel put new plug in cleaned air filter,drained all fuel and leand cou carborator (we found little condinsation in it) Does and one please have any ideas on whats the problom is
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
  • 196 Answers
SOURCE: wheres the oil drain plug for model 7021 CH1
Most horizontal 4 stroke engines have them on the bottom next to the crank/output shaft that the blade rides on. Tip the mower on it's side and look under it. You should be able to see the bottom of the engine. If it's full of grass/dirt, brush it off. You should see the drain plug.
Posted on Apr 30, 2010
SOURCE: husqvarna 7021 kohler 173cc looks like its leaking
The carburetor probably needs cleaning -- the float is sticking.
Charlie
Posted on Jan 07, 2011
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Posted on Jun 28, 2011
Knucklebstr
  • 222 Answers
SOURCE: PROBLEM STARTING OF HUSQVARNA 7021
An engine needs three things in order to start and run; 1. Spark 2. Compression 3. Fuel. Sounds like you've got good spark if the engine starts, so it seems you may have a fuel problem. This could be several things, from a kinked fuel line or a bad gas cap, to a plugged or gummed carburetor. The carb is usually the issue if your machine has sat for any time with Ethanol Gas in it. The carb should be taken apart and thoroughly cleaned with a good carb cleaner (better left to a professional if you're not familiar). Your machine appears to have a Honda engine on it and I have had problems with stuck valves on them. The valve cover is right up front and if you prop the front of the machine up, can be removed without losing your oil. Make sure the valves are working properly and not sticking. One more possibility is that you may have struck something hard with the blade and knocked the timing out of whack (broken timing key underneath the flywheel. That's the best I can do without actually looking at your machine. Best of luck to you.
James
Posted on Nov 08, 2011
Briggs and straten...875...190cc will not stay running,it`s surging the whole time and then just stops
It sounds like you may have a cracked float in the carburetor. It surges and when the float is saturated, it stops. If you don't feel comfortable putting in a rebuild kit, you may need to to take it to a small engine repair place.
Feb 22, 2015 | Briggs & Stratton Briggs Stratton...
After mowing the mower will not start after it is cut off to clean-been in shop 4 times?
I'd say check the oil and make sure air filter and cooling fins are clean, but I assume the shop will have done that. Has a fuel line gotten run too close to something hot? Might not show up when started and run at the shop, but would after running under load.
Aug 15, 2014 | Husqvarna 61 Mz6128 Zero Turn Lawn Mower...
Husqvarna
Gas filter might not run properly and it must be replace. If it gets bad enough the lawn mower might not turn on and in worse case gasoline could start coming out the air pusher.
Aug 05, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawn mower husqvarna problem
Jul 29, 2010 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Wheres the oil drain plug for model 7021 CH1
Apr 30, 2010 | Husqvarna Rear Propelled Rear Bag Lawn...
Husqvarna 160 CC Honda OHC Engine 21 in Logo
260 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
