Question about Metrologic Instruments HoneywellMetrologic MS9590 Voyager GS Scanner USB withEAS Stand Barcode Scanner
I have a Metrologic MS9590 set up and am having problems with it transposing the first few digits of barcodes. The problem only occurs when scanning into a highlighted cell (eg. Cell is highlighted blue but there is no cursor). I tried setting up a prefix "enter" character which worked but unfortunately caused other problems. Any help would be greatly appreciated.
SOURCE: ms9520 buzzez and then will not scan
The Razzberry Tone is what I'm hearing. Acording to the trouble shooting I should return the unit for repair. Thanks for you help!
Posted on Jun 07, 2007
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
SOURCE: Default Barcode as the one used in the manual
I finally figured out the problem, thanks to Here4you's help.  The Metrologic VoyagerBT does indeed use the 128 barcoding protocols.  The reason my barcodes were not scanning in properly is that the correct barcodes had a hidden "Function-3" prefix, which all of the scanner's programming codes have.  I am still having trouble figuring out how to input a "Function-3" prefix into the various barcode generation programs I am testing.  I use Macs, not PCs so many of you may be inclined to recommend certain programs that are are exclusively made for PCs.  I will be creating the data for the barcodes in either Excel or Filemaker, so I am attempting to input the ASCII equivalent for the Function-3, with mixed results.  Thanks for the help!
Posted on Jan 09, 2008
SOURCE: Metrologic USB Voyager scanner
refer your scanner manual and scan the default barcode printed ,then scan the use interface barcode printed properly
Posted on Feb 02, 2008
Metrologic ms9535 4 beeps - whilst fully charged on cradle - still scans ok but nothing in manual to say what the problem is. Any ideas?
The battery can be found for around $35. Just search Metrologic ms9535 battery, or the battery part number itself, 46-46870.
Sep 23, 2011 | Metrologic Instruments MS9535 VoyagerBT...
What kind of cables do I need? my friend says that they are doggles - or something like that
RS232 Barcode Scanner Cable
Handheld scanner cable
Connector: DB9, DB15, RJ45
Cable: PU, PVC, 26AWG, 28AWG...
Application: Computer POS system, Scanner 0R Metrologic Honeywell barcode scanner MS9540 MS5145 USB Cable ???4 Similar from this Supplier Straight USB Cable with chip for Honeywell Metrologic MS5145, MS9540, MS9590, ETC....
May 04, 2011 | Computers & Internet
How do i get it to connection
You have to set-up the barcode scanner in the manual. The most common mistake is not scanning the "host" option. The scanner default is "no host" It will not work until you enable the appropriate "host" option by scanning that particular barcode. Read the manual. Contact the Honeywell Help Desk (they bought Metrologic)
Nov 03, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Scanner ouput is missing data from the scanned barcode
yes i have the same problem, when i am using usb keyboard..
but if u use standard ps2 101-102 keyboard it is working properly
Aug 13, 2009 | Microsoft Metrologic MS9520 Voyager...
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Scanner won't scan red ribbon
metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
Jan 02, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Not scanning 2D
hello Having loaded the reader to metroset, print setting on paper and you read on paper. This player does not confugura with usb. give me answer. Roberto
Apr 07, 2008 | Metrologic Instruments MS1690 Handheld
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments HoneywellMetrologic MS9590 Voyager GS Scanner USB withEAS Stand Barcode Scanner Logo
318 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
