Question about Tec Patio II Grill
My Tec Patio II grill will not stay lit. The pilot burner works but the tiles just woosh and go out. I use portable gas canisters. I would like to take it apart and clean the gas jets but need a service manual or instruction on how to do so. I can not tell from reading your terms whether there is a charge for seeking this advice. If there is please let me know what the cost is before it is given to me so I may have a choice. Thank you.
  • 140 Answers
It is not your Gas jets it is your burners they or clog or crack,When that happen too much air gets in there they go out Replace them and that will take car of your problem!
Posted on Aug 06, 2010
  • jdearle Sep 30, 2010
    I have had a Patio II grill since 2002. It is the best grill I have had in 30 years of BQing. I agree with gcken, the problem is the ceramic burner plates, they are probably cracked. I have replaced the plates 3 times - they were covered under warranty and shipped promptly from TEC. I did pay postage. Try calling TEC 803-783-0750, they are great people to work with. If you need suggestions for how to replace the plates email me jearle9@yahoo.com
How to replace burner and convert to natural gas
Hey, Well here is a link for parts for your model http://www.ibuygrillparts.com/model/patio-ii--barbecue-grill and here is the part # for your conversion kit P2CKLP-NT If you have any questions try calling 1-888-634-4289 and speak to Paul, he helped me out with my grill.
Apr 24, 2013 | Tec Patio II Grill
TEC Sterling II, Pilot light not lighting ceramic burners. Got new ignitor. It does create a spark but it doesn't jump to the pilot light or to the burners.
The gas may not be reaching the burners. Try match lighting a burner to see if it is. If it isn't do the following.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. If you're using as 1 Lb
Canister tank. Turn the valve off and remove the canister.
2. Wait 5 minutes and reconnect the hose to the tank. Reinsert the canister.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. Or you will have to replace the Canister Assembly. For that you'll have to go to Tec Grills. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 08, 2011 | Tec Sterling II Grill
Has Patio II for Grills gone out of business? Need to replace our burner in ours. Any idea of where to get parts other than maybe ebay? Thank you so much
Assuming you are talking about the TEC Patio II grill. it is made by the Thermal Engineering Corporation of Columbia South Carolina http://www.tecinfrared.com/home.php. the burners are sold as complete replacment parts as well as pieces of the burner sold seperately. It has a ceramic insert as part of the infrared burner. You may replace just that portion if that is all that is bad. if this has failed on your grill I would highly suggest spraying the four bolts that hold it in place (visible from the top of the grill with grates removed) with a penetrating oil several times over several days before attempting to remove them. Mine came out just fine and the grill is 12 years old. I love this grill even though there is a built in 12000 dollar grill on my patio.good luck
Jun 10, 2011 | Tec Patio II Grill
The ignitor sparks but the pilot light doesn't light. Can this be fixed? (Tec Patio II Grill)
I have the same problem with my 12 year old Tech Patio II. Have you found a solution? I will call the manufacturer myself to see if they can help. They are most helpful.
Leslie
May 27, 2010 | Tec Patio II Grill
Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
May 17, 2010 | Tec Patio II Grill
I have a Patio II that is about 10 years old. The
you can order new ceramic plates from tec it is only clipped in they should be able to send instructions
Aug 10, 2009 | Tec Patio II Grill
Tec Grill Sterling Model won't stay lit
The dealer is right. The ceramic burner is cracked. It will need to be replaced -- pretty pricey. I have the same problem on my Sterling III. This DOES happen too often. My opinion is that this IS a manufacturing defect. I have called the company about it (they are in South Carolina) and they try to blame the user -- that would be us. Very unfortunate company chooses to act this way. You hear about this problem again and again and again -- it's their problem but sadly, they are making it ours. Remember that when you go grill shopping next time -- I know I won't buy a Sterling grill again. Ever.
Feb 15, 2009 | Tec Patio II Grill
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
Tec Patio II Grill Logo
340 people viewed this question
Top Tec Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Tec Grilling Expert? Answer questions, earn points and help others
