Question about Husqvarna Designer I
I have a Husqvarna 1+, how can I connect my laptop to it to download embroidery designs?
    New Friend:
  • 194 Answers
Sorry,... there is not a connection to allow you to do that. However there is a Reader/Writer unit that you can plug into a USB port on your computer and write a design to the card that comes with the reader/writer and then put the card in the machine to embroidery a downloaded design.
Doug
Posted on Aug 05, 2010
pgmadhav
  • 145 Answers
SOURCE: Husqvarna 1 Embroidery software
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 20, 2008
kent581
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
  • 152 Answers
SOURCE: Can't get computer and embroidery machine to connect.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Posted on Oct 10, 2009
  • 152 Answers
SOURCE: husqvarna viking designer 2 embroidery machine. Wont work on my
Buy a PC, or get the program that mac has that supports pc programs. I've seen it work so I'm sure it's an optioin. Mac people don't like the program, but it will create an environment that supports PC programs.
Posted on Oct 24, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
I just bought a used Designer 1 ESS machine and I do not know how to use the dongle
You don't need a dongle for the sewing machine. You either have a dongle for the computer embroidery software in which case it goes in your computer when you've installed the software, or you have a USB stick that has the Husqvarna designs on it.
What colour is it? The USB sticks are blue, the 3D software dongles are red. Only problem is, I think the 4D software dongles are blue too!! My Husqvarna Designer 1 USB embroidery stick (blue) has "USB Embroidery Stick" written on it - have a look for that. The dongle will have Hasp or something like that written on it.
If you are pretty sure it is a USB stick, put it in your machine and turn it on. Then touch the disk/stick icon on the lower right hand side of the screen. Your machine should start to read the stick and you will get a pop-up menu where you can choose from the folders on the stick. If you don't, go into the PROG screen. Touch MENU, touch the disk/stick icon and see if the embroidery files on the stick come up then. Each machine came with a set of designs called Embroidery Disk 100 and three alphabets - Palace Script, Kaligraphia and Clarendon. These should all be on the USB stick.
In the event that it is a dongle you have, but not the software, you need to contact the person from whom you purchased the machine.
You can download the Husqvarna designs from the Husqvarna website, but you will need a Husqvarna formatted USB stick to do this. Therefore, you do need software on your computer. There are some low-cost alternatives to the Husqvarna software - Embird and Sew What come to mind. However, a Husqvarna program called 3D Disk Manager USB came with every USB Designer 1 machine, so you should have got that when you purchased the machine. This will be enough for you to load designs from the HV website and from other websites where you purchase designs.
Nov 25, 2010 | Husqvarna Designer I
My laptop which has windows 7 on it does not recognize mmy dongle
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
link to latest Dongle Drivers - http://vsmsoftware.net/downloads/HASP/HASPUsersetup.exe
Husqvarna Viking - http://www.husqvarnaviking.com
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Good luck..
Feb 13, 2010 | Husqvarna Designer I
I the floppy discs that control my Designer 1 embroidery machine
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
Good luck.
Dec 29, 2009 | Husqvarna Designer I
Can't get computer and embroidery machine to connect via USB. Computer doesn't recognize embroidery machine. (Husqvarna Designer Diamond) I also have a new DELL laptop.
Jul 12, 2009 | Husqvarna Sewing Machines
Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Jan 10, 2009 | Husqvarna Viking 1
Dec 20, 2008 | Husqvarna Viking 1
Husqvarna rose
go to radio shack with the lap top and the embroidery card reader and show the things to a knowledgeable tech and get a adapter. now, do you have the software for the card reader so it can be installed onthe laptop? how about the software interface?
Nov 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
196 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
