Question about Husqvarna Garden
Put in a carb kit because it would not start now it will start but will not idle unless the choke is on full
  • 760 Answers
Probably not getting enough gas. Make sure the gasket that has the little flappers in it is on right. these act like check valves. Make sure all passage ways are completely clean.
Posted on Aug 05, 2010
Testimonial: "thanks for the info clean for sure will check gasket for the third time frustrated"
1985 Ford Ranger 2.3 starts and idles good. But when put in gear dies until it reaches full temp.
Hmm...........
1985..........
Probably carb? Automatic choke not working? Remove air filter and spray carb with cleaner, Make sure all parts move freely. With engine cold, check automatic choke position. Start and check function as it warms up.
Feb 21, 2016 | Ford Cars & Trucks
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
99' Suzuki GXS-R 600.. Won't start unless you pull the "CHOKE" and stalls if you turn off the Choke. Also it sputters at idle, I drained the tank and put in fresh gas, replaced air filter... want to...
overhaul the carburetors or just take them apart and clean them you may have needles sticking and jets plugged, buy a kit, and or clean all pieces of carb inside and out with gum out carb cleaner and put back together blow all airs out with compressed air. When done screw in air fuel mixture screws all the way and turn counter clockwise out 3 full turns to fire it up then adjust accordingly.
Oct 11, 2010 | 1999 Suzuki GSX-R 600
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
Starts and idles will not run above idle unless choked. Have cleaned carb multiple times new fuel filter new air cleaner and cleaned exhaust screen new plug. Maybe a collapsing fuel line?
Have you tried adjusting the carb? There should be two screws on the carb (hi & Low) turn the hi screw completely until it stops and then start the unit. Let it warm up and then begin to back the screw out until it starts to run smoothly but strong. Once you have it running then put it in full run position (choke) and you should be good.
Feb 19, 2010 | Echo Inc. 44 CC, Carb Certified Backpack...
Small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Sep 25, 2009 | Garden
1999 enfield 350cc bullet, won't tickover without full choke
Idle jet in carb may be blocked. Carb will have to be dismantled and cleaned out.
Aug 06, 2009 | 2000 Enfield Bullet 350
Yamaha SR125 Carb Problem
Sounds more like when the reinstalled your carb after cleaning, they did not ensure a proper seal from the carb to intake manifold. This is common! It could be no more than an intake leak. Start your motor and Spray a little WD40 just behind the carb on the intake seals. Be carefull not to spray into the throat of the carb as this will cause a false reading. A variance in the idle of the motor when you do this indicates an intake leak.
Jul 13, 2009 | Yamaha SR 125 Motorcycles
05 750 brute force missing badly
Just had same problem. Take carbs off and clean all jets and bowl. Be carful front and rear carb have different sized jets. When you put quad back together put entire airbox together even the cover. This quad will backfire unless air box is complete. I bet you anything your carb is full of trash.
Jan 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Garden Logo
77 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
