Question about Epic Overstock T60 Treadmill Treadmills
My treadmill does good under speed level 3 (which is good for slowly walking)- if I go past that level is shuts off after a minute. I've tried pushing the restart button and nothing happens? what do I need to do?
  • 9 Answers
First thing is to get yourself an appliance load tested that can measure amperage draw from a power outlet. plug the tester into the outlet and the treadmill into the tester and verify you are set for amps. at 3mph without being on the treadmill you should see around 2.5 to 3 amps of power draw. If you are seeing much higher than this then the motor may have a dead short which is causing the motor control board to overheat and shutoff - if this is happening within a couple minutes you may be pulling 3 times the amps it is supposed to. to remedy that you would need a new drive motor as the motor is what causes the shutdowns and overheating
Posted on Aug 05, 2010
Nordictrak T5.7 treadmill squeaks while walking
please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Jan 08, 2013 | Exercise & Fitness
Tip
How to reset/recalibrate your treadmill after replacing drive or incline motor,...
Make sure you recalibrate your treadmill after installing ANY controller, motor or console. You can NOT over calibrate your treadmill. You want to make sure you adjust your pedometer for the correct operating speed and incline adjustment. First plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. The adjustment is made with a phillips screwdriver, and the adjustment point is on the motor controller. It is a little square metal box with a yellow plastic adjustment screw inside. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode. Double check that the treadmill is operating at the correct speed and incline motor works correctly, by running maximum settings. Once you are done, be sure your treadmill is properly protected from surges from power spikes that can destroy the work you just performed.
Hope this helped.
on Dec 08, 2011 | Nordic Track Exercise & Fitness
I have an E-4 sign coming up on the treadmill. I still dont have a clue how to calibrate it or anything. i bought it over the internet and there was no instruction manual that came with it. i really need...
Dear Sir:
This is guide for software calibration in Horizon. Please see under your Hood for motor the instruction for step in calibration.
Turn the treadmill power to "On." Place the safety key in its place on the treadmill console.
  • 2 Simultaneously press and hold the incline "+" and speed "-" buttons for approximately five seconds: The console will beep and display the software version in either the "Time" window or the "Calories/Elevation" window.
  • 3 Press "Start" and allow the running belt to begin moving. The belt should start at 0.5 mph. If this speed is not the speed your treadmill starts at, adjust the speed cube screw located under the control board. Turn the screw to slowly to the right to increase the speed or slowly to the left to decrease the speed.
  • 4 Verify this speed is correct by counting the running belt revolutions per minute. At 0.5 mph, the running belt should make four revolutions in a minute for the Alpine and Advance 500 models and four-and-a-half revolutions for all other models.
  • 5 Press and hold the "Stop" button for three seconds to exit the engineering menu.
  • sincerely. God bless you.
    ernesto cuadra
    managua, nicaragua. c.a
    Feb 11, 2012 | Exercise & Fitness
    Incline reads 0.0 but is not all the way down
    Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
    Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
    Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
    Smooth fitness treadmill beeps every two minutes
    Walk on a treadmill to calculate distance.
    Most electronic treadmills allow you to program for an alarm or beep when you've walked a certain distance.
    Try to turn off reading your owner manual.
    And check if there are some error code?.
    If you do not have owner manual go to this web:
    http://www.smoothfitness.com/support/product-manuals.htm
    and download free.
    sincerely.
    Nov 22, 2011 | Exercise & Fitness
    When I start my treadmill, I have to increase the speed very slowly- otherwise it shuts down and I have to turn it off and back in again. It takes about three minutes of gradually increasing the speed to...
    This problem coming:
    1) Speed sensor : misaligned you must do it, otherwise, you must change it.
    2) Please see if some wire is broken, loosen, or pinchen, or maybe clean with alcohol isopropyl 100% for to clean( dust, grease, oil)
    3) Motor is faulty: brushes, or winding, or some wire loose, broken, or pinching.
    sincerely.
    E.CUADRA
    Nov 03, 2011 | Proform Exercise & Fitness
    Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
    HI,
    Its time to lubricate your treadmill.
    You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
    for make it easy for you I have added a video. ok
    Aug 27, 2011 | Reebok Exercise & Fitness
    My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
    simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
    good luck to you.
    Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
    I started up my treadmill after a year sabbatical :) to find that it stops abruptly when I increase the speed above 4 and then when I restarted it as soon as I stood on the belt the motor lagged & then...
    If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
    Apr 28, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
    E2, E3, E4 CODES ON A SEARS LIFESTYLER EXPOSURE 1500 MACHINE STARTS OK BUT SHUTS DOWN W/ E CODES AFTER A FEW MINUTES.
    an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
    Jan 07, 2010 | Exercise & Fitness
    Epic Overstock  T60 Treadmill Treadmills Logo
    195 people viewed this question
    Top Epic Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Colin Stickland
    Colin Stickland
    Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
