Question about Tunturi T40 Folding Treadmill
Hi, We have had our treadmill for about 3 weeks. For the past few days, when we start it up, after about 15 seconds of running on it, it stops and Error 1 shows up on the screen. It is a t40 model. Unfortunately we have moved to Nunavut in northern Canada and won't be able to access service up here even though it's under warranty. Any help would be hugely appreciated!!
  • 9 Answers
Error 1 is a fairyl universal code for treadmills that means your control board has gone bad. Here is a list of things that will cause this to occur:
1. Improper lubrication of belt/deck (too much friction and amperage draw)
2. electrical variance (example: going from US 110 to foreign 220)
3. potentiometer on control board may be set too low (usually blue box with turnable dial) - to change this you would have to turn the dial ever so slightly and test after each movement until the belt starts to run on its own without the error.
other than the above issues you would have to replace the motor control board
Posted on Aug 05, 2010
  • Clemencia Saavedra Jan 20, 2014
    Thank you. I will check on it.
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Why is error 3 coming up treadmill works for a few seconds then stops and error 3 comes on
hi,
You didn't mentioned the brand of the treadmill. Its necessary to ad the make and model number, then only you someone would be able to help you sole the problem.
www.electro-medical.blogspot.com
Aug 25, 2015 | Exercise & Fitness
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 13, 2013 | Cadence Exercise & Fitness
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
TX400 STARTS BUT WILL NOT KEEP RUNNING FOR ONLY A FEW SECONDS
see the video and lube the deck + rollers bearing. This happen because the lack of maintenance.
If after you lube the problem remain, TIME to replace the old board deck
.God bless you
Feb 28, 2013 | Sportcraft Exercise & Fitness
NordicTrack A2105 console is very faint to read
It sounds like the upper console has a loose connection ( check wire harness connections in the upper and lower board section ) or the upper console is failing call Icon Fitness @ 1-800-999-3756
Jun 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
Car shuts off after 2-3 seconds
I would start with having the battery and alternator tested. I have seen this problem in many a vehicle in 90 percent of the time its one or the other with a chance of both items being bad.
Sep 14, 2009 | 1996 Chrysler Town & Country
Speed fluctuates randomly
Try calibrating the console. If it doesn't work, you'll need a new motor control board.
Feb 15, 2009 | Reebok 8050 ES Treadmill
Tunturi T40 Folding Treadmill Logo
352 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Marvin
Marvin
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
