Question about Sanyo Office Equipment & Supplies
I Have a Sanyo PROxtrax multiverse Projector Model # PLC-XP57L and it says to change the Lamp. I have put two different lamps in it and it doesn't Light and the replace lamp light comes on. I do ger 32 VAC and up to 85 VAC until the lamp fail indicator comes on and I don't get Contanewety between wire connection of the Lamps what do I do next
  • 89 Answers
You will have to reset the lamp timer as well
Posted on Aug 10, 2010
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Ive put a new lamp in my Sanyo PRO-x Multiverse projector PLC-SU30 but still not working. I've been told I need to reset the machine by pressinmg a combination of menu buttons - is this correct and can...
I'm having a similar issue wit a Sanyo. Installed new Sanyo lamp but when you plug it in the warning indicators show that there is no lamp detected. Ballast issue? Sanyo tech support told me this is rare. I'm not all that confident about the lamp socket. it seems to be a loose fit. Can't find any info on a reset.
Aug 12, 2010 | Sanyo (6102932751) Projector Lamp for...
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
Aug 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Can't get the lamp light to turn off on my sanyo xp57 projector. replaced the lamp and the lamp warning light won't shut off.
Go into the menu and look for the settings icon. Under the setting icon you should see a lamp counter reset button. Select that and the lamp replacement light will go out.
Jul 30, 2009 | Sanyo PLC-XP57L LCD Projector
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
No light being projected from unit,
I will guess that your lamp is dead, buy a new lamp.
And if u want to buy a lamp to the lowest price u can get, buy it from www.pricejapan.com
Good luck
Dec 01, 2008 | Sanyo PLV 70 Multimedia Projector
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo LCD Projector
Hi smnheffernan
If there is no LED's switching on , then you can definitely rule out the lamp.
Try opening up the unit by taking out all the screws at the bottom and taking of the top cover.
Then repalce the fuse that is on the Powersupply Board ( the one that has the AC socket on it )
If the problem there after still exists , you will have to replace the Powersupply Board.
Hope this is of help and thanks for using Fixya !
May 05, 2008 | Sanyo PLC XU35 Multimedia Projector
848 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
