Question about Canon PowerShot SX110 IS Digital Camera
Lens error, restart camera. - Canon PowerShot SX110 IS Digital Camera
    Sergeant:
  • 420 Answers
Try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 12, 2010
t00nz
  • 4738 Answers
SOURCE: Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 03, 2008
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jun 28, 2009
ginko
  • 19396 Answers
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
  • 64 Answers
SOURCE: Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Posted on Sep 12, 2009
  • 11967 Answers
SOURCE: My Canon A590 is saying lens error restart camera.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 29, 2009
Lens error.. I have restarted & restarted camera..still same lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2010 | Canon PowerShot A420 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
Jun 28, 2009 | Canon Cameras
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
How do i restart my canon camera?
Restart means turn it off and on. But I believe that you failed to mention the other words that go with this error, namely "Lens Error, Restart Camera". Sadly, restarting the camera usually does not work to correct the lens error.
Oct 11, 2008 | Cameras
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Lens Error, Restart
Dec 31, 2007 | Cameras
Canon PowerShot SX110 IS Digital Camera Logo
697 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
