Question about Panasonic DMR-E75V DVD Player/VCR
It won't play any DVD's that were recorded by itself (it will still play other DVD's). This problem just started happening and I've owned it since new (i'm guessing 5 years). Less than 300 DVD's were ever recorded with this machine.
Probably should buy a new updated one.
Posted on Nov 05, 2010
  • hottasalsa Nov 05, 2010
    Perhaps buying a new one is your answer.
    Guess you should buy a new one.
    Hottasalsa
I have recorded on a Verbatim DVD+RW disc on my Philips 3305 DVDR but it will not play back on my friend's Panasonic DMR-EX98VEB. My recorder will not finalise/make compatible the disc. Why?
Could be that the disk itself is incompatible with your friend's machine. Or your buddies machine may be starting to exhibit playback issues. Try another disk and see what happens.
Feb 07, 2016 | Panasonic Televison & Video
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Panasonic DVD-S31 won't play sound
Did you change the audio cable, "just to rule out" If it won't work on the Tv or stereo, there probably is a audio processor problem, or a issue with the laser pickup assembly, to repair this kind of problem would not justify the cost.
Apr 12, 2012 | Panasonic DVD-S31S DVD Player
How do you unlock an Audiovox D1788?
Hello
Enter the Menu screen, select, preference, select default, and OK.
If the problem is with password forgot, the default passord of this unit is [ 3308]. Enter this password on the first screen. Sometimes the unit won't accept this passord for the first time to cheat you, enter this pasword again. After that, you can enter your own passord. OK.
Nov 17, 2011 | Audiovox D1788 Portable DVD Player
At digital change over , will my dvd/tape recorder still work. type DF-4100p
It will still play DVDs and videos, and record from one to the other, but you won't be able to record from TV onto either format now. (I know: I've got one!)
Sep 04, 2011 | Daewoo Televison & Video
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Nov 02, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DVD-S47
There are DVD players that have a feature that automatically skips the menu and plays the largest title on the disc (typically the movie). It's usually not an advertised feature. maybe pressing "play mode" on the remote can fix that. Since you're having more problems, it will probably take more then disabling that feature, or you might be looking at 2 separate issues. What happens if you take the battery out of the remote? does that stop it? and what happens when you press FF on the player itself? this should tell you if the problem is specificaly with the remote, or with the player itself. Best thing to do though is use the warranty if its still valid, or consult the shop on repair options. Good luck
Mar 22, 2006 | Panasonic DVD-S47 DVD Player
Panasonic DMR-E75V DVD Player/VCR Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
