Question about Rohl A3608LMAPC Single Lever Country Kitchen Faucet with Metal Lever Handle...
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed in or on and that it is stripped?
    Sergeant:
    Champion:
  • 277 Answers
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Posted on Aug 05, 2010
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
When the lever on my Vestige faucet is turned to the hot side, it chatters and stops running when the hot water reaches it.
It sounds like you have a foreign body in the hot line,turn off water both cold and hot disassemble handle assembly including springs and washers slowly turn on hot water to see if object will flush out,if not disconnect hot water supply to faucet the turn on water supply slow ly to see if object is in supply line.If that dosen't work you may have to call plumber it may be in supply stop or below it and you need a professional to handle that.
Jun 10, 2011 | Moen 7065ORB Vestige Single-Handle Kitchen...
Water leeking from sprayer button whether or not sprayer is activated
You have a seal in spray head that's gone bad or has displaced itself,you can disassemble the spray head (note how you take apart so it is put back correctly or you will have a worse problem)check that all seal are complete and not torn or broken if they are you may have to get repair kit also use plumbers grease or vaseline to lube all seals when reinstalled.
Jun 07, 2011 | Blanco Classic Single Handle Faucet with...
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Water leaking from top section of kitchen faucet
You might try replacing the o-rings but I would replace the cartridge and the o-rings. Be sure and use silicone lubricant on the o-rings.
Feb 23, 2010 | Plumbing
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | American Standard Plumbing
Rohl A3608LMAPC Single Lever Country Kitchen Faucet with Metal Lever Handle... Logo
199 people viewed this question
Top Rohl Plumbing Experts
Paul Carew
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
