Question about Memorex (32023292) DVD±RW Dual Layer Burner
I have a Memorex DVD burner x16 Double Layer. I connect it to my Windows XP PC via USB cable. The computer does not see the drive wither in My Computer or in the Device Manager.
    Sergeant:
  • 271 Answers
Try another USB plug or cable.
Check if a power cable is needed.
Posted on Aug 07, 2010
Can I use this device connected to my Acer Aspire R14 (which does not have a dvd slot), to play dvds?
Yes the drive runs on usb .I did not use there install software .I used VLC player (free ware) because im using windows 8.1. hope this helps.
Jan 06, 2015 | Memorex 8X Slim DVD Dual Layer...
How do i connect an AD-7710H to USB?
You can purchase a SATA to USB converter from a number of web sites, but it would be just as cheap to buy an external USB DVD writer.
Jan 18, 2014 | Sony Ad 7710h Internal Dvd Writer Dual...
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Not recognize
Update your windows and the restart you pc after plunging out from electricity for 3 minutes
Oct 15, 2013 | LG GSA-2164D (8801031211579) DVD±RW Dual...
Installed a new dvd burner with lightscribe and my comp runs really slow
Please enable DMA by right clicking on the CD drive icon and go to the DMA tab.
Jun 22, 2012 | Memorex 24x Dvdrw Drive With Lightscribe -...
The DVD Burner will not burn a Memorex DVD - R . Should I purchase Verbatum or Memorex for an older model MSI DVD Burner? Or, Should I purchase Verbatum or Memorex for an older model Samsung TS H652...
You are on the right track. Every "multi-format" DVD recorder, DVD burner and DVD-RW drive I have ever owned has had problems with one type of media or another. This is because the discs all have their own patented dye mixtures, and each is a little bit different.
I have problems using Memorex DVD-R discs on my Toshiba DVD recorder. The only drive I can get good results with Memorex DVD-R's is on my Memorex DVD drive.
For DVD-R media, I have had the best success with TDK DVD-R's.So far, they have worked on all my devices.
You may want to try DVD+R media. I use Memorex Lightscribe DVD+R and for dual layer recording, I use Ativa DVD+R DL discs, both of which have worked very well and I rarely have to throw one away.
It takes allot longer, but on my PC I always use the "verify" function to make sure I get a good copy.
Feb 17, 2011 | Samsung TS-H653F DVD±RW Dual Layer Burner
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Acts like a Player/CD burner
    I have an IDE Memorex DVD±RW Dual Layer Burner (52x32x16) that has burned well over 300 cd/dvd' sense 2004 when I bought it. In 2006 or 7, an update was given to it via memorex sight - I was told to keep a copy of the dn ld, for it can't be undone and became "IDE Memorex DVD±RW Dual Layer Burner (523216)AJ___NWK____\5&265FB54&0&000" MODEL - I got it on sale from Fry's Elec. - It seems that it was indeed a 1 way ticket - and it is time to retire the old work horse anyway - Quite happy with your products and getting me another. PS - I don't think the upgrade did any justus
    May 04, 2009 | Computers & Internet
    Need to find out how to install my memorex double layer 16x
    Ok here is what you need to do. Open the box that the driver came in and also the side panel of your computer. Remove the cables that are attached to the current CD-ROM drive and if you need to unscrew the screws that are holding the CD-ROM drive in place which you'll need a phillips screw driver for. Remove the old CD-ROM and put in the new one and reconnect the cables to the new one. If an installation disk came with it then put that in the CD-ROM drive and install whatever is on that disk. Afterwards you should be ready to go. If you need anything else please let me know!
    Apr 05, 2009 | Computers & Internet
    Memorex (32023292) DVD±RW Dual Layer Burner Logo
    108 people viewed this question
    Top Memorex Computers & Internet Experts
    Jax Planet
    Jax Planet
    Gbenga
    Dennis Gutowski
    Dennis Gutowski
    Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
