Frigidaire 18,500 btu installed about 2 weeks in the wall and has been working great...It is tilted down on the outside, however this evening it started blowing drops of water inside the room..About 1 drop every 3-4 minutes..... It is in a room 30x20 and there was no stove or anything on, however there was a door wide open leading into a out 40 feet of the house at the time was not air conditioned....any suggestion...Doug Hogan
    President:
  • 2,559 Answers
Sounds like over condensation caused by the uncooled area but may also be a clogged drain hole on the outside of the unit
Posted on Aug 05, 2010
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Frigidaire Heating & Cooling
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Is there a drip hole,itsgot water in it
Try Check on the underside, or sides near the rear of the unit (outside) you should see it there. Some have and some do not, most of the water evaporates, or Spills over the edge at the rear of the unit, if you have it installed correctly you should'nt have any issues with water in there.
Jul 04, 2012 | Kenmore 18,500 BTU Heat/Cool 230V Room Air...
Brand new (3 weeks old) 14K btu Frigidaire blows cold on and off. Serviceman came out (when it was working) and found nothing wrong. Are they just junk or what?
No sometimes the problem is intermint if it just three weeks old take it back for a new one. Dont wast your time for a service call, its cheaper ti repace.
Jul 17, 2010 | Frigidaire FAH146R2T 14,000 BTU...
Do you need brackets for outside wall installation for the frigidaire 15000 btu air conditioner.
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
May 11, 2010 | Frigidaire FAH085N1T Air Conditioner
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Heating & Cooling Logo
    16 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Marvin
    Marvin
