Question about Ruud UBHC Air Conditioner
Ruud 90+ I am getting a code off the board. The code is 4 blinking lights off of the top light in the circuit board. What does this signify?. Furnace will not operate.
  • bigdaddy8076 Apr 26, 2008
    Got the problem fixed. Was the furnace unit, not heat pump. Pressure switch was stuck.
    Thanks
  • Brent Kahl May 11, 2010
    Need more information, is the unit a heat pump, is the board on the fan unit or the out door unit? Is this a split system or a package system (all in one outdoors)?
Removed the flex hoses from the pressure sensors and reinstalled them. Unit reset and now works perfectly.
Posted on Apr 27, 2008
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Furnace main fan comes on but the furnace doesn't come on. The indicator red light blinks four times. What does this signify?
You have to get in to the main circuit board. At the bottom of the circuit board it will tell you what the flashes mean, in very small print. Read this print for you codes.
Dec 25, 2009 | Goodman GMS90703BXA Heater
Ruud achiever 90 plus won`t start
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Feb 05, 2009 | Ruud UBHC Air Conditioner
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Jan 19, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
186 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
