Question about Robinair (ROB40153) Two Way Wheel Manifold Gauge Set with Hoses
Having problems with parts for my 15600 pump - Robinair (ROB40153) Two Way Wheel Manifold Gauge Set with Hoses
  • 43,501 Answers
2011 Honda XL1000V Varadero tire pressure
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.honda-varadero-uk.org/forum/index.php?topic=5990.0
http://www.xrv.org.uk/forums/varadero-technical-specs/15600-varadero-specs.html
Honda Varadero MK1 XL 1000 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XL1000V Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 15, 2014 | 2011 Honda XL1000V Varadero
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 17, 2012 | Hardware & Accessories
Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
Sep 11, 2011 | GE Vacuums
What would be the result of 10 squared times the sum of 10700+4900?
10^2 = 10 x 10 = 100
10700 + 4900 = 15600
100 x 15600 = 1,560,000
Jul 03, 2011 | Audiovox Computers & Internet
I am replacting my T103 timer with a GE 15600. The posts on the T103 are marked 1 2 3 4. However on the 15600 they are marked L 1 X 2. How do these map to each other?
5) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Garden
Seem to have a belt slipping problem. The motor runs but the belt is not turning. Have been trying to get new belts. IMPOSSIBLE !!! I have two machines...148 15600 and 385 1233280
I assume you need belts for both machines? Searspartsdirect (SPD) are the best place for Kenmore replacement parts.
There are 2 belts on the 385 1233280 - the timing belt and the drive belt. Both are in stock at SPD and can be obtained by clicking on the following link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851233280/0582/1220000/00024020/00008?blt=06&prst=&shdMod=
If you hover over the exploded parts diagram you can see a larger view. The timing belt is number 7 and the drive belt is number 15. If you scoll further down the page you can add them to your shopping cart.
They also have both belts for the 148 15600. They are numbered 16 and 17 in this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-14815600/0582/1220000/00033316/00008?blt=06&prst=&shdMod=
Again both are in stock, and can be ordered by scrolling down the page and adding numbers 16 and 17 to your shopping cart.
Yoiu may be able to get these from a Sears store, but you can any which you need from here.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Vacuums
Robinair 15600 Vac. Pump
Check your pump oil level,It should be middle of sight glass while pump is runing & try to use origenal vacuum pump oil.
Apr 05, 2009 | Robinair 6 Cfm 2 Stage Vacuum Pump, R 12/R...
Robinair (ROB40153) Two Way Wheel Manifold Gauge Set with Hoses Logo
42 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
