Question about Samsung HZ10W / WB500 Digital Camera
I dropped my camera and now when i try to turn it on, the lens opens, then closes and beeps three times. i am able to view my pictures that were taken prior to this, but I am unable to take pictures. My camera is a Samsung HZ10W
  • Samsung Master
  • 3,866 Answers
What might have happned is when you dropped your camera the autofocus mechanism inside got busted, These are very delicate and cannot take drops that well, picture this as dropping a glass bottle on the ground 90 percent of the time it shatters correct?
So does the iris inside these cameras and so does the auto focus mechanism that tells the iris basically whats going on.
Steps you can take
1. Take the battery fully out then put the battery back in and turn it on if the iris is logged it will dislodge and work again. If its busted well then this step will not work then you need to go to step 2.
2. Take it to a local shop
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 05, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 05, 2010
    if you have any additional feedback please click reply to expert or the accept button for my efforts in helping you today,
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Camera
clean off the lens and any other open areas when you dropped it..
Aug 08, 2008 | Cameras
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung HZ10W / WB500 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
