Question about Sharp MX-3501N All-In-One Printer
Sharp mx3501 code h4-02, - Sharp MX-3501N All-In-One Printer
2 Suggested Answers
  • 46 Answers
SOURCE: Our Sharp copier MX3501 is
The scan location (i.e. email, ftp, network folder, computer with sharpdesk) can't be found check the address details and make sure they are correct.
If it is a sharpdesk scan then the most likely reason is that the IP address of the computer has changed (DHCP).
If FTP or Email check the address of the server you are sending to.
Your IT or Service provide should be able to help give you the correct addresses and authentication settings for these.
Posted on Oct 21, 2010
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Our Sharp copier MX3501 is sending a message that selected servers cannot be found. How do we correct?
Oct 21, 2010 | Sharp Office Equipment & Supplies
I have a Sharp Mx3501 and the waste container needs to be changed. I was asked if I cant just empty the container. Can I? Is it even safe to do so?
yes just remove the bottom white/clear plug and empty it carefully into the trash can, replace plug and you should be good to go.
Oct 23, 2009 | Sharp MX-3501N All-In-One Printer
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Code for rca rcr311b remote to sharp tv
Feb 04, 2009 | RCA RCR311B Remote Control
Sharp 3501 copier-scanner
there are options you can buy that will do what you ask the best thing is to call your Authorized SHARP dealer
and ask for a connector for the mx3501
Nov 30, 2008 | Sharp Office Equipment & Supplies
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Sharp MX-3501N All-In-One Printer Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
