Question about Sanyo Televison & Video
The television was working and was shut off. It was turned back on and no picture just sound. The screen is black and I do not know what happened. Sanyo model #DP26648
  • 11,361 Answers
Unplug it for about an hour to let it reset itself, if it is still does not work, then you need to do some troubleshooting.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 05, 2010
Tv turns on with sound, black screen and then turns off
Most likely failing capacitor see this thread, http://www.fixya.com/search/p153336-mitsubishi_wd_62525_62_in_rear/common_capacitor_fail_tv Maybe a electronics reapir person...
Apr 08, 2014 | Mitsubishi WD-62825 62" Rear Projection...
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
No picture but there is sound
think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 10, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Picture shutting off
sounds like a cold solder. a connection that was soldered, wasn't properly. if it is still under warranty send back. if not then have repaired.
Sep 30, 2017 | Philips 26PF8946 26 in. HD-Ready LCD...
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Nov 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
119 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
