Question about Sony DCR-DVD810 DVD Camcorder
My camera sony dcr-dvd819 indicate code error E:94:01. I need know what do, please.
SOURCE: Camera Case will not close
I solved my Sony Camera problem by throwing the camera in the trash and vowing never to purchase a Sony Camera again. When I saw many other people posting the same problem on the internet, I came to the conclusion this is a major problem with Sony Cameras.
Posted on Jun 19, 2008
SOURCE: camera flashing error E:91-01
This worked for me: With camera power on, push RESET (located left of the rec button in the main panel).
Posted on Apr 28, 2009
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
  • 41 Answers
SOURCE: blinking error code C:21:00 how to remove from sony camcorder
Try depressing the small "Reset" button with the camera power on. Use a sharp pencil/ball point pen to do that. It resets the logic in the camera and may help.
Posted on Feb 03, 2009
  • 30 Answers
SOURCE: sony handycam DCR-DVD108 - - error e:61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously(FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Posted on Mar 29, 2010
Sony Handycam DCR-PC109 NTSC minicam--"Reinsert
The C31 indicates that there is a motor movement problem. I don't have the manual handy at the moment, but the :23 will indicate which movement is having the problem. This is not typically a DIY repair. I woul d strongly suggest that you check the fixed repair cost from a Sony authorized service center. This will not only repair the unit, but also reset it back to factory specifications.
I'll look up the error code tonight and try to update this.
Dan
May 26, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-TRV22 camera
HI! THE ERROR CODE C:32:10 IS A TAPE LOADING ERROR. IS A TAPE STUCK IN THE CAMERA? IF IT IS OR NOT FOLLOW THE FOLLOWING INSTRUCTIONS TO CLEAR THE CODE!
1.UNPLUG THE AC CORD FROM CAMERA.
2.REMOVE FAT BATTERY.
3. REMOVE SLIM BATTERY, FROM UNDER THE LCD-ABOUT THE SIZE OF NICKEL.
4. WAIT 2 MINUTES.
5.PLUG THE AC TO THE CAMERA.
6. FLIP THE CAMERA TO THE VTR MODE.
7. TAPE SHOULD EJECT AND THE CODE SHOULD CLEAR.
OK? HOPE THIS SOLVES YOUR PROBLEM. DON'T KNOW IF THIS WAS ALL OF YOUR PROBLEM, BUT IT SHOULD SOLVE THE ERROR. IF YOU NEED HELP REPLY TO:
ARCLIGHT1217
Nov 06, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony DCR-TRV19 Problem: None of the functions except cassette ejection will work. Error Code:C:31:23
Error code 31:23 shows problem in Take-up Reel section of your Sony Camera. If you know about camera repair, please check Take-up Reel section in tape mechanism and if you don't know, please contact nearest Sony Service Center for proper repair.
Aug 17, 2008 | Cameras
Dcr-trv520 error code C:31:23
For those that said to reset your camera, thanks.
DCR-trv520 handycam. Left power on, took out battery. Waited a minute.
Put battery back in. Worked liked before.
Thanks.
Jul 24, 2008 | Sony Handycam DCR-TRV520 Digital Camcorder
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Error code sony dcr trv25 c:31:23
Nov 19, 2007 | Sony Handycam DCR-TRV80 Mini DV Digital...
Dcr-dvd 205 error code
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 05, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony DCR-DVD810 DVD Camcorder Logo
472 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
