Question about Maytag MGS5770 Gas Kitchen Range
The oven does not heat up properly the bottom portion not getting hot at all
  • 3 Answers
I have the same problem ive replaced the safety valve and the heating element on the bottom. go to bellparts.com and type your model number in and look at the wiring diagram i think it has to do with the red wire going to the terminal block or it can be the contactor on the terminal block it self good luck let me know if you get yours fixed
Posted on Aug 09, 2010
  • terencebklyn Sep 06, 2010
    Ive fixed the problem with mines it was the whole clock assembly ive ordered one off ebay i offered him $65 maybe due to it being a very old model but on averge they sell for 100 go to bellparts and type your model number
    p.s it was the contactor associated with the red wire
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
How do I check to see if the oven is working properly?
You need to
A/ FIRST TURN THE OVEN OFF COMPLETELY.
B/ Get access to the terminals ( usually at the back of the cooker)
C/ Disconnect the wiring from the terminals, there will be 2, 1 on each terminal.
D/ Obtain a multimeter and set it to ohms
E/ Place 1 lead on each of the terminals and check the reading in ohms on the scale.
F/ No reading on the meter indicates the heating element has gone open circuit or blown.
G/ Obtain make/serial number/type. Order a replacement from a supplier of heating elements.
Sep 15, 2014 | Whirlpool GMC305PDS Electric Double Oven
Oven heat temp.. small ven only heats from the bottom, oven only has 2 settings..urgently neen to know how hot is hi, and how cool is low..plwase?????
Get yourself an oven thermometer they are available for a few dollars at most homeware places, put in in the oven and you will be able to get your temperatures easily.
Apr 18, 2014 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Dec 06, 2011 | Electrolux Ovens
Viking professional gas range isn't heating properly
The ignitor must glow brightly, if it is dim it is probably too weak to open the bi-metal safety valve. Take a LOOK
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | Ovens
Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
The oven is constantly burning things I cook. If I reduce the heat - food doesn't cook properly and when you use the correct heat, the bottom on the food is burnt black. Can anyone help. Also no way of...
There are other possibilities, but,..... this sounds like what will happen if you use too large of a pan or cookie sheet(s) in your oven. If there is not much space on the sides and front and back of the pans, the heat gets trapped under the pan (causing burning) because not enough hot air is getting to the top of the oven where the oven thermostat is located.
Sep 23, 2008 | Kitchen Ranges
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
Oven won't start
If you look at the oven igniter in the bottom portion of the range, (where the gas controls are) look to see if the igniter is glowing hot. If not, replace your igniter. This is the part that starts the burner and keep it lit. When you get a new igniter DO NOT TOUCH THE ELEMENT PORTION of the igniter. Or it will pre-maturly fail. Good luck.Hope this helped ya!
Dec 07, 2007 | Frigidaire FGF378AC Gas Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Maytag MGS5770 Gas Kitchen Range Logo
98 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
