Question about Arctic Air 22 cu. ft. / 623 liter Upright Freezer F22CW
Artic air upright freezer F22cw3, has suddenly defrosted several times, now fan runs but does not freeze - is this an easy fix or an expensive one and who is close to harrisburg, pa
  • Dennis Boxerman Jan 15, 2011
    which fan runs? Inside or the one by the compressor. Is the compressor running?
fridgetech
  • 473 Answers
SOURCE: upright freezer
Three things could be the problem. Most likely would be the defrost thermostat which clips onto the evaporator behind the panel in the freezer. 2nd would be the timer or control board (will have one or the other). 3rd would be a bad defrost heater. Alot of times the def. therm. will show obvious sign of being bad by the cap on top popped open. You can check resistance on the heater. Any resistance at all on the heater means it is good. If it has a standard timer turn it clockwise until it clicks. This is putting it into defrost. If the heater comes on the timer is bad. If it has a control board you would unplug the unit then unplug the power supply to the board and jump line 1 to the wire going to the heater. While unplugged from the board and jumped, plug the freezer back in. If the heater comes on then the board is bad. If you are not sure how to test replace the def. thermostat, which is the cheapest part and see what happens. Note: When conducting the test for the timer or board the def. therm. must be freezing so don't defrost first! Hope this helps.
Posted on Oct 06, 2007
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
  • 306 Answers
SOURCE: Defrost hose plugs
Remove the back cover to access the top of that drain line. Take some table salt in a tablespoon and dump in the tube. Will drain so fast you won't believe it. Might have a big build up of ice blocking the top so get your hair dryer and defrost that big build up. Flush with small amount of water and monitor the drain pan located under neath the freezer. hope this was helpfull
Posted on Nov 26, 2008
  • 10 Answers
SOURCE: My woods upright freezer keeps
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Posted on Feb 07, 2009
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
It is running but is not freezing the food
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Good luck.
Apr 12, 2011 | Freezers
My whirlpool chest freezer runs but does not freeze?
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
I have an older commercial upright Hobart freezer. The freezer seems to operate fine, cycling but always returning the compartment to zero degrees, until all of a sudden the temperature went up, well...
In most cases, an evap that freezes up is either an air flow problem or no defrost cycle. Older Hobarts have mechanical defrost time clocks. It could be locked up i.e., not running so no defrost cycle.
It could be coming out of defrost too early because the sensor that monitors the evap temp is not working properly.
The door could not be closing. If left cracked open, it will freeze up every time as unit never hits temp., keeps unit running. Warm air is seeping in and the moisture freezes on evap.
Lastly, the defrost heater(s) may not be working. Burned out, shorted, broken wire, etc.
Good luck and hope this helps.
Mar 28, 2009 | Victory Commercial Freezer VSF-3
Arctic Air 22 cu. ft. / 623 liter Upright Freezer F22CW Logo
87 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
