Question about Garmin nuvi 1250 Car GPS Receiver
Won't turn on...garmin nuvi 1250 - Garmin nuvi 1250 Car GPS Receiver
mattozan
  • 555 Answers
SOURCE: garmin nuvi won't turn on
Sounds like it needs a firmware update.
Posted on Jun 18, 2008
SOURCE: Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Posted on Feb 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: Garmin Nuvi 1250 has a dim screen when plugged
I would venture a guess that the cable you are using in the vehicle is not a genuine Garmin cable. The units are very sensitive to voltage.
Anything under approximately 10 volts - the Garmin assumes it is plugged into a USB port (Active Cradle)... not a vehicle... and it dims for quicker charging.
Switch to a Garmin OEM cable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 19, 2010
walesarumi
  • 6993 Answers
SOURCE: my garmin 1250 wont turn on
check the battery first, it might be very weak, that's why its not turning on.
Please let me know if other wise.
Take care.
Posted on May 18, 2010
bbl242003
  • 1637 Answers
SOURCE: when the garmin nuvi 1250
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 21, 2011
Tip
Garmin Nuvi 1250 Favorites Backup_2
Garmin Nuvi 1250 Favorites Backup and Restoration Procedure
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1250 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1250 Manual Download
Garmin Nuvi 1250 QuickStart Download
Garmin Nuvi 1250 Webupdate
Garmin Nuvi 1250 Hard Reset
on Jun 18, 2010 | GPS
Tip
Garmin Nuvi 1250 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1250 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Download Garmin Nuvi 1250 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1250 GPS?
Would you like a digital copy of the Garmin Nuvi 1250 Users Guide for easy searching of terms and quick reference?
The Nuvi 1250 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1250 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1250 GPS?
Would you like a digital copy of the Garmin Nuvi 1250 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1250 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1250 Favorites Backup and Restoration Procedure Models: Nuvi...
I hope that helps.
on May 15, 2010 | GPS
Tip
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
on May 15, 2010 | Garmin nuvi 1250 Car GPS Receiver
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1250 Car GPS Receiver Logo
516 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
