Question about Toshiba Satellite L305-S5902 15.4 Notebook Intel Pentium Dual-Core T3200 2.0GHz / 2GB RAM / 160GB Ha...
Toshiba sat: A305-S6857 need to do recovery suppose to be in a special partition on computer HDD. No disk came with system. How do I do recovery?
  • tigrpet Aug 05, 2010
    F8 & F11 did not work, is there another way of accessing partitions?
  • Toshiba Master
  • 6,993 Answers
to confirm if your laptop has a recovery or not, click start menu and click my computer. Under computer, check if you will see a recovery driver. If you see the recovery drive, then it means your computer has a recovery.
To run the recovery, click start > all programs > Toshiba Back-up and Recovery. Follow the instruction on the recovery page in order to proceed for the recovery.
Good luck.
Posted on Aug 05, 2010
  • Toshiba Master
  • 17,446 Answers
When the computer is starting you can press F8 or F11 to enter a menu that has the restore function listed. IT will do all the work and install from the hidden partition.
  • Brad Brown Aug 05, 2010
    Press and hold the 0 (zero) key on your keyboard while
    powering on the computer. When the computer powers on, the
    Toshiba Recovery Wizard screen displays.
    (Sample Image) Toshiba Recovery Wizard screen
    Select one of the options, and then click Next. The options are:
    ❖ Recovery
My A305-S6857 freeze every time when I tried to login. I cannot access to my desktop.
Try doing a startup repair by pressing F8 repeatedly on startup. On the options menu, choose 'repair my computer'. If this isn't successful you can try running your antivirus software in safe mode to check for any infections. Press F8 as before and choose safe mode. If this works, you can also check your event viewer to see if there are any system errors recorded: control panel>system and security>administrative tools>event viewer. Expand the critical and error menus under 'summary of administrative events' You can double click on an event for further detail and the event ID which may help you troubleshoot the problem further.
Apr 03, 2012 | Toshiba Satellite A305-S6857 Laptop
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
My toshiba satellite a305-s6857 powers up but in less than a minute or two, it restarts, and there's no message that a certain hardwared has failure. I also checked the memory and no problem either. I...
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes.Choosing no will start doing a system restore.
You need to go to start>control panel >system> advanced>start up and recovery>and clear automatically restart.I hope this helps you.Thank You & good luck.
May 18, 2011 | Toshiba Satellite A305-S6857 Laptop
I have the Toshiba Satellite A305-S6857, and lately whenever i play music, or watch movies, or videos online the sound and video will skip or become delayed a couple seconds as if the computer is...
you do have something else running in the background and its using the internet, probably spyware or malware. run your anti-spyware program and check, if you don't have one, you need to try "malwarebytes" or "spybot" they are free programs
Mar 19, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Hi i need to restore my Toshiba A100 - TA2 Model # PSAA8C - TA202C i had a virus on it and it crashed my computer before i could get it fixed... Please email me back on how i can fix my computer myself...
Using the Toshiba HDD Recovery Utility from the recovery partition
In the event of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in the special partition on the hard disk drive).
You can elect to restore the entire hard disk drive to the factory default state, or to restore only the C: drive -- without affecting other partitions (for example, a D: drive) -- or to change the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computer's HDD, follow the steps on this link:
http://tinyurl.com/4jkfsek
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 17, 2011 | Computers & Internet
No hdd recovery area!
have a look at this link and see if it helps you out. No hdd recovery area Google Search
Oct 13, 2017 | Toshiba Satellite A305-S6908 Laptop
My satellite a505 laptop has windows 7 on it and was wondering if i was supposed to get a disk with it so i could reinstall it
Uusally, now a days you do not get a disk with a new computer. Instead, if you go into the toshiba folder under programs on the start menu they will have a utility to make recovery disks. These disks can then be used to completely redo your computer should you need to.
Hope this helps.
Feb 21, 2010 | Toshiba Satellite A505-S6975 Notebook
FM radio tune with fm antenna on a305-s6857
My laptop is Toshiba M300 and I use FM Tuner Utility under NXP FM Tuner in all programs.
Mar 14, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite L305-S5902 15.4 Notebook Intel Pentium Dual-Core T3200 2.0GHz / 2GB RAM / 160GB Ha...  Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
