Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Posted on Jan 12, 2016
  • 235 Answers
SOURCE: Cabrio won't spin and has standing water
The coupling might have broken in place and will not allow the motor to do its job. It's a $7 part that goes on the motor shaft.
Posted on Jun 28, 2009
SOURCE: Washer does not work but gives an OL CODE with just two shirts.
OL means overload
Posted on Sep 07, 2009
SOURCE: Washer does not spin
My washer has been repaired. The control board was bad & the new one fixed the problem. They also replaced the sensor on the bottom of the washer while they had it apart since he had an extra one on his truck. Fortunately, even though the machine was 1 month out of warranty, Whirlpool agreed to cover the parts and labor.
Posted on Jan 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 09, 2010
  • 171 Answers
SOURCE: Washer will not spin after draining.
the long drain code means that either the pump is bad or there is an obstruction to the water flow.  check the hose going to the washtub and also check for obstructions in the hoses at the pump itself.  if clear the pump is probably bad.
Posted on Aug 03, 2010
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
Ol code cabrio
"oL" error code, even when unloaded - Fixitnow.com
fixitnow.com/.../whirlpoolkenmore-cabrio-and-maytag-bravo-washers-th...
Sep 18, 2010 - The "oL" error code in the Cabrio and Bravo washers means the ... is almost always caused by using non-HE detergent in this washer- see this ...
Aug 17, 2015 | Washing Machines
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Cabrio washer is getting OL code after about 10 mins.
see http://forum.appliancepartspros.com/washer-repair/192305-cabrio-washer-code-ol.html as more ideas on this type of problem suggested
Mar 27, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Screen say OL on my Kenmore Catalyst Elite. What does oL mean?
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
Feb 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Washer stops and shows oL over load
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
Nov 01, 2012 | Whirlpool Washing Machines
2007 Cabrio does not agitate, flashes oL code even when empty
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub.
Oct 14, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SB2 won't spin or agitate. We bought it used and they swore it worked. It goes from 45min and drops down to 3mins. It never completes it's load. And after it beeps with a OL on
Hi.
Most spin troubles are caused by drain or pressure switch problems, but it does not look like that is your case. Check for blockage in drain system and clean the hose connected to pressure switch. As said I do not think that this is the problem but the drain system must be checked as part of troubleshooting.
OL code in fact is not related to drain problems, but to motor and mechanical problem. OL is returned when the washer is overloaded and the motor cannot turn the basket properly.
The first step to diagnose the problem is removing the basket and looking for problems under the basket (e.g. broken part or clothes stuck under the tub). Here a document showing how to.
If parts under the basket are OK the next step will consist in testing the motor. The motor can be tested reading impedance at its phase terminal and across the stator winding. The Cabrio's motor should read about 30/32 Ohms across its phase contacts.
If the motor and the rest are OK the problem is usually the RPS sensor that detects the rotational speed of the motor.
Regards.
Ginko
Dec 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
353 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
