Question about Sun SPARCengine ULTRA AXI (SEUAXI-440R-0B) Motherboard
ON POWER ON HAVE NO VIDEO OUTPUT TO MONITOR - Sun SPARCengine ULTRA AXI (SEUAXI-440R-0B) Motherboard
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
Which key outputs video (screen) to projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 17, 2012 | Dell Latitude D510 Notebook
EeeBox PC EB1007 doesnt boot
Don't assume that a lack of video is a bios issue. I'd first look at the monitor and then the video card.
Use another monitor to check the output. Unfortunately, your video circuit is integrated with the motherboard. Unless you have a PCI card to put into the computer, you won't be able to easily identify a video problem.
I have seen, though, a bad power supply affect the video output so that is an area to check.
Apr 20, 2012 | ASUS EeeBox EB1007 (EB1007B003F) PC...
How do i get monitor output
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a lkeycombinations for the laptops :-HP and Compaq = Fn + F4
Mar 11, 2012 | HP Compaq nc6120 Notebook
The computer was in use when the display cut out. The monitor is fine and the computer turns on but has no display on the monitor
I presume that you tried the monitor on another system to verify function. Try restart after 2 min power down and disconnect and try again, then take another "known good" monitor and try that. If both monitors give no image, video output is suspect. Many motherboards have the video output as part of the board itself, cost prohibitive to replace motherboard.
Sometimes you can plug in a PCI video card and bypass system video.
Oct 01, 2010 | Gateway GT5622 PC Desktop
Back light comes on with power up but goes out after about half a second
hey..try to unplug your video cable of your monitor in your CPU.. then power on your monitor...if there is a sign appears goes like this..." no video output..or "no signal output" your monitor is ok and the problem i inside you pc..if you need further help you can contact me...
Feb 06, 2010 | IBM 2704hb7 (Black) 19 in. Flat Panel LCD...
Power saver problems
Did it come out of power-save mode when you connected it to the other computer?
Does your laptop have a "toggle":
* video-output only to internal LCD screen
* video-output only to external monitor
* video-output to both displays
If so, toggle the setting to "external" or to "both".
Dec 14, 2009 | LG W2252TQ Monitor
No power but ON button flashing
Quickest fix for this is probably to temporarily unplug the monitor power cord.
For your other outages, I assume the monitor is connected to a computer, make sure the operating system power-save features have not disabled the video output signal from the computer ... if so, monitor should re-activate when you use the mouse or hit a key on the keyboard.
If your computer has two video outputs, make sure the primary display hasn't been shifted to the other one ... try it by moving the LCD data cable to the other video connector on the computer.
Dec 26, 2008 | Westinghouse LCM-19v1 Monitor
Sun SPARCengine ULTRA AXI (SEUAXI-440R-0B) Motherboard Logo
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
