Question about GE AHG40LA Dehumidifier
I have a GE Dehumidifier that is icing up. I cleaned the coils, condenser, and everything else to no avail. The fan works fine and is moving plenty of air. It does have an automatic defrost, but it does not shut off when iced up. Could this be the problem. If it is how do I fix it.
  • GE Master
  • 43,501 Answers
Add more freon to unit... Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 30, 2010
How do I clean the dehumidifier?
A dehumidifier works just the way an air conditioner works but in a reverse manner. If you encounter a problem with your dehumidifier then it would be repaired the same way you would repair an air conditioner. As such a dehumidifier does not require much cleaning apart from changing the filter. When the filter and coils of the dehumidifier are choked with dirt, it may not pull out moisture from the air properly. The efficiency of the dehumidifier gets decreased and the only solution is, to clean it thoroughly. In order to assist you with the cleaning procedure of a dehumidifier, following are a few tips:
  1. Remove the water tank/container and clean it after draining the water. Depending on the usage the container must be cleaned regularly.
  2. Cleaning or changing the filter is also important for the main function of ensuring a healthy atmosphere is performed by the filter. Mix some bleach with warm soapy and clean the filter. It will help to get rid of the bacteria, molds and mildew.
  3. Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off the dirt using a brush but make sure that you don’t bend the fins while cleaning.
  4. Clean the condenser or the cold coil the same way. If the humidifier is working in a room where the temperature is below 60 degrees Fahrenheit then check the coils whether it is not icing up.
  5. See to it whether the fins are bent or not, if they are bent then straighten them out using a fin comb otherwise it might obstruct the effective working of the dehumidifier.
  6. And yes do not forget to clean the fan blades and other parts of the dehumidifier.
  7. Keeping in mind the humidity level of your room, sets the humidistat of the dehumidifier as keeping it too low or too high may only make the dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Aug 17, 2010 | Fedders A7DH45B2A Dehumidifier
This summer I have ice build up on top of the unit. I have a drain hose so the bucket is not full. I have cleaned the air filter. I have also removed the front grill and used a fine brush to remove dust...
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils.
To remedy this problem, you can try any of these:
Warm up the room the dehumidifier is in.
Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Take care.
Aug 12, 2010 | LG LHD45EL Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Coils freezing up, is this normal during operation?
Check fan speed. Also if coil (it's the evaporator) is clean.
Jun 02, 2010 | Maytag M7DH45B2A Dehumidifier
Unit works fan runs lights turn on but no water in the bucket,
Some units use the condensate water to cool down the condenser coil. This is why no water is present. If water is leaking from the unit or you are still sceptical about this problem, I would call for service.
Mat
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
Dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Jul 02, 2008 | GE AHG40LJ Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifiers Logo
362 people viewed this question
Top GE Dehumidifiers Experts
Gene Tuck
 steve
steve
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
