Question about Kenmore 74602 Gas Dryer
Take off bottom panel to clean lint - Kenmore 74602 Gas Dryer
  • 37 Answers
BethBelle -- Two nut-drive/flat-slot machine screws (near floor) hold bottom panel in place. Write if you have further questions. -- SWT
Posted on Aug 05, 2010
How do you reset the control panel on a whirlpool quiet partner II dishwasher?
It should reset automatically. There could be lint buildup inside the dryer airflow inlet that is located just inside the door on the bottom. There could be lint buildup at the exhaust vent at the back on the bottom of the dryer.
Nov 09, 2015 | Whirlpool Dryers
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY IT IS WORKING BECAUSE IT HEAT BUT THE CLOTHES ARE WET
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Oct 13, 2011 | General Electric Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
How to clean out lint at the bottom of lint tray?
remove front panel by releasing clips holding top to front. use putty knife and press in on 2 hidden clips. top will lift, hinged at back, then find two screws holding front to sides, remove and lift panel up and out. clog in these is very common at bottom of plastic duct on panel going into blower.
Jul 05, 2009 | Maytag PYE2300AY Electric Dryer
The control lock does not work. Tryed everything to unlock the
It is not inlocking because of water still in the system, run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot open the bottem panel to clean out lint
ok please always unplug first...you will fine two clips between the top panel and the bottom panel almost to each corner,,take a small putty knife and push in...onthejob
Nov 12, 2008 | Whirlpool GGQ8831L Gas Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 74602 Gas Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
