Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I have a dayton 3/4 hp fan motor. I need to change voltage from 230 to 115. Where can I get a wiring diagram showing the wire changes that I need to make. I have done this before but forgot which wires go where.
  • 760 Answers
There are many different types of motors. you should have a diagram on the inside of the wiring compartment cover. This is a dayton diagram, but I can't be sure it is the same as the motor you have.Notice line terminals remain the same, but that the internal wires change terminals.
I have a dayton 3/4 - 25d910c.jpg
Posted on Aug 05, 2010
Testimonial: "Just what I was looking for. Thanks"
    New Friend:
Mine says to put black on # 2 which is a direct short because it is coming from L1 to L2 ??? yes it arched and trip the ckt breaker
I have a dayton 3/4 - 2_11_2013_5_10_02_am.jpg
Posted on Feb 11, 2013
2 Suggested Answers
  • 92 Answers
SOURCE: just replaced a rheem oem 1/6 hp motor 3 wires
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Posted on Jul 10, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Wiring diagram for dayton 5k652a motor
Hi. I think these website may be able to show or provide that diagram you need: industrialscientifictool. Com. Or. freeproductmanual.com. I hope this helps
Mar 22, 2015 | Dayton Dryers
I have a Dayton Pahse 1, 3/4 HP motor that shows 115/230 volts on the label. I just had an outlet coverted to 240. I plugged it in and the motor barely moves and sounds like it is stuck or not enough...
there should be a diagram on the label for 110 or 220v-are you sure the last garage you ran it in was 220-it should only run at one of those levels without re-wiring the motor-cheers Denny
Oct 29, 2013 | Dayton Permanent Split Capacitor Motor Fan
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2012 | Dryers
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
I have a dayton 1 1/2 h.p electric motor, and need the wiring diagram for 460 volt. the part number is [1] 3n013bb. thanks
Line is L1 L2 L3 to line voltage. wire nut 4-7 together wirenut 5-7 together and wirenut 6-9 together connect 123 to line for low voltage 123 together 456 together 679 together. This works on all dual voltage 3 phase motors. Some of the newer Daytom motors have a plug that you just turn for changing voltage. Rudty
Jun 03, 2009 | Heating & Cooling
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton 1/2 hp dual voltage motor overheats (mtr #6k79). Replaced original motor with same motor overheats in 10 -30 minutes. White lead to #4 terminal, black lead to #1 terminal, ground to casing.
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Jul 23, 2008 | Dayton Heating & Cooling
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
1,234 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
