Question about Motorola Mobility T 4900 AA RADIO, T4900 AA, 2PK
What frequency do they broadcast at? - Motorola Mobility T 4900 AA RADIO, T4900 AA, 2PK
    President:
  • 2,761 Answers
FRS/GMRS frequencies range between 462.5625 and 467.7250 MHz.
Let me know if you need the individual channel breakout.
Bill B
WQJV930
Posted on Aug 06, 2010
How can I tune the radio to 87.7? It keeps telling me it doesn't exist even though that is a radio station in our area.
FM frequency assignment is not a simple matter. See https://en.wikipedia.org/wiki/FM_broadcasting_in_the_United_States: "In the United States, frequency-modulated broadcasting stations operate in a frequency band extending from 87.8 MHz to 108.0 MHz," But you might want to read the remainder of this Wikipedia article; it explains how this frequency is almost always used by TV stations (which use the FM band for their audio). Or, you may want to Google "87.7 FM" for more insight; that search turned up a station in Boston and one in Chicago supposedly operating on the 87.7 frequency. But your best bet would be to contact that station and ask them how to receive their broadcasts; I'm sure this wouldn't be the first time someone has had this problem.
Feb 10, 2016 | Ford Taurus Se, Sel, Sho, Limited...
How do i tune Mazda Demio (2004 model) radio to Southern African frequencies?
fm frequencies are just that fm frequencies ( not japanese, chinese ,english or anything else
it is a range of frequencies in the fm band that local stations broadcast on
so all you have to do is to turn the tuner knob until you get 107 fm
so as you turn the knob you will loose 89 and it will go probably 90.5 , 100.20, 102.7 etc and if there is a station broadcasting that your radio will pick up it will come in and then fade out as you keep moving the knob
you may have to change the mode as there are fm 1 ,fm 2,fm 3 bands to get your fm 107 as it will depend on what megahertz 107 is operating on
Oct 05, 2015 | Mazda Cars & Trucks
How do you get the cobra walkie talkie to say the weather
Provided that your 2-way radio has the feature, there should be either a dedicated weather button or somewhere in the menus. Not sure what model you have. If it is a more advanced radio where you can set the frequency, the list of weather broadcast frequencies taken from NOAA are listed below. Two way radios are normally automatically programmed to one of these frequencies and usually require a push of a button.
Nationwide Station Listing Using Broadcast Frequencies
162.400
MHz 162.425
MHz 162.450
MHz 162.475
MHz 162.500
MHz 162.525
MHz 162.550
MHz
Jul 02, 2014 | Radio Communications
Why is it recommended to have a roof aerial for the DVBT broadcast? a; In order to receive any signs of DVBT broadcasting stations, from a great distance b; In order to receive more signs of any D
First thing to think about is what frequency of radio is DVBT on ?
I think you will find that the Analogue tv was VHF where as digital tv is on UHF .
This means that the wavelength of radio signals on UFH is smaller and as a result radio waves do not bounce as readily in the Air and thus the coverage range is less efficient as compared to VHF.
Also being a smaller wave length a new antenna that can cater for the different frequency ranges of digital TV would be required
To efficiently receive a radio signal the antenna's yagi elements have to each be at a length that is at a multiple of the wavelength of the radio frequency. Either 1 or 1/2 or 1/4.
wavelength = speed of light (299792458 metres per second)/ frequency in hz
Feb 26, 2013 | Televison & Video
How do I get the BBC on the Grundig S350?
You need to know the broadcast frequencies (or wavwlengths) and the times at which BBC is broadcasting towards you part of the world. With frequency in hand tune in to it at the time BBC is broadcasting towards your location. There is a book which is published annualy. The title of the book is World Radio Handbook or some such thing.
Jan 08, 2011 | Grundig S350 AM/FM/SW Radio
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
Short static burst
I don't know a whole lot about microphones, but if it's wireless, then it has to accept interference according to the FCC. Wireless microphones normally connect using RF transmitters/receivers which can normally be tuned to specific short-range broadcast frequencies, which can be interfered with by passing waves of other frequencies. Even if the broadcasted radio waves aren't the same frequency, or within the same bandwidth, the harmonic distortion radiates at multiples of the fundamental (broadcasted) frequency.
If you can, try changing channels and see if that clears things up. If not, then perhaps contacting the manufacture can help.
Jun 03, 2010 | Sennheiser (EW165G2A) Professional...
Motarola VT2542 Wireless Router: If you disable the wireless on the router's software does that stop the router from broadcasting rf frequency? I would like to use the router as a wired router without rf...
Hi! It's ok to disable the wireless broadcast of the router however, it wont stop the router from broadcasting the wireless frequency. It will only hide itself from the people who are trying to connect to a free signal that are available.
Dec 19, 2008 | Arris Wireless G Broadband Router (wr850g)
Motorola Mobility T 4900 AA RADIO, T4900 AA, 2PK Logo
99 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
