Question about Sharp AF-S120FX Air Conditioner
Our air conditioner is shutting off after it is on for short period of time, the filter is cleaned, we have no clue what to try, the error code is e1 please help asap, it's 85 and humid.............
  • 2,133 Answers
E-1 error code means room air sensor defective. Replace it.
Posted on Jan 09, 2011
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Tip
Excess Electricity bill
If unit service periodically, it cuts our electricity bill by 10% . Air filter must be cleaned every fortnightly. By passing safety switches, neglecting error codes will cost expenditure more.Repair at once whenever you see any error code.
on Jan 10, 2011 | Heating & Cooling
I´m P-08 code
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Due to short of gas/evaporator & air filter blocked/less rpm of blower motor.
Remedy: Find leak and arrest and do gas charging/clean filter & coil/replace B.Motor capacitor.
Jan 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
MY AC SHUTS OFF AND CODE E1 COMES UP
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:1. Power down the air conditioner using the "power" button on the front panel.2. Unplug the air conditioner from the wall socket.3. Hold the front panel "power" button down and plug the airconditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.4. Unplug the air conditioner.5. Plug the air conditioner back in.6. Congratulations! You should now be able to operate the airconditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Jul 22, 2010 | Sharp AF-S120FX Air Conditioner
We have a portable air conditioner. It keeps
Follow the steps below....
panel.
button.
Jun 26, 2010 | Heating & Cooling
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Error code on air conditioner e1
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Jun 09, 2008 | Heating & Cooling
Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Jun 09, 2008 | Frigidaire FAA065M7A Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
217 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
